Here's the new Bridge Tailpiece PROTOTYPE 2...still a little rough but functional.
3/4" x 1/2" aluminum angle and plywood (3/4" and 1/4") channel
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1050003.jpg)
1/4 " channel base/reinforcement fits inside the 1/2" x 3/4" angle which as been cut down slightly on the 1/2" leg width so the channel bears directly against the body. It gets tacked in with superglue and drilled thru for the mounting screws
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1040976.jpg)
Same bridge I've been using with individual height/length adjustment, don't have an uncut one to show.
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1050012.jpg)
Saddle carrier gets cut narrower after being sized to fit inside 3/4" I.D. channel. Plenty of adjustment if bridge is located properly.
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1050001.jpg)
Carrier with saddles and channel
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1050011.jpg)
In place, screws are too big. I have smaller ones, took the pictures for me to realize they're better.
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1050009.jpg)
![](http://i976.photobucket.com/albums/ae241/cata1d0/2012%20%20BRIDGE/P1050006.jpg)
Need to make the next one for ThunderBucker's Epi FenderBird and get his input. Because this bridge fits flush against the body it's easy to get low action with minimum neck angle.
