The Ampeg V-4B 100W All-Tube Bass Head embodies the legendary tone of the classic V-4B in a portable, modern design perfect for today’s players. From the unique chassis suspension system to the vintage rocker switches, the attention to detail is all there. Plus, with a careful selection of modern features like an integrated DI and a wide choice of speaker output options, we’ve ensured the flexibility and functionality you demand from a modern head. With the 100W V-4B, you get the sought-after tone of a fully-cranked Ampeg tube amp in a design that’s less than half the weight of an SVT.• 100W of all-tube Ampeg bass toneo Preamp: Tube ( 2 x 12AX7)o Driver: Tube (1 x 12AX7, 1 x 12AU7)o Power amp: Tube (4 x 6L6GC)• Classic V-4B fit and finisho Ampeg “Black Line” cosmeticso Vintage rocker switch controlso Integrated chassis suspension system• 3-band EQ (bass, midrange, treble)• 3-position mid-range control• Ultra Hi/Lo boost• Speaker outputs: 1 x 8 ohm, 2 x 4 ohm, 2 x 2 ohm• Balanced direct out w/ ground lift• Power amp in / preamp out• -15 dB input• Slave output to connect additional amplifiers• Dimensions (W x H x D inches): 24 x 11 x 11• Handling weight: 41 lbs
They put it on their Facebook page yesterday. I don't fully trust ANY post-SLM production Ampeg. An amp company run by a real-estate venture capital group with a consistent recent track record for extremely unreliable products is going to have to work doubly hard to impress me. If this amp, like the SVT VR, gets the look and sound but is built to be unserviceable with plenty of construction corners cut, it's just another reason to buy an old one. Show me an internal picture Ampeg.
Well, just for grins, here's what the insides of the coming "Heritage" B-15 looks like compared to an original...
Yup. That knob pcb is a problem waiting to happen and very few of the component parts in that amp could be replaced if they failed. It's built like a computer: cards to be swapped- the reason that REAL engineers are a disappearing breed.
My 72 V4B was the best sounding bass amp i ever had.
While you can replace things on a board, I get your point. I had to recap a pc motherboard some months ago just for kicks. Not fun.
