Author Topic: Peelings. Wo-oh-oh-ooo peelings... (BaCH NR and a stripper)  (Read 38332 times)
Re: Peelings. Wo-oh-oh-ooo peelings... (BaCH NR and a stripper)
« Reply #45 on: August 29, 2009, 06:34:04 PM »
I got the block sanding done this afternoon.  I used the styrofoam and eraser tricks for around the edges, heel, and tummy contour - this really helped.  I was being ultra careful not to alter the contours.  I have a big rubber sanding block that I used for the larger flat surfaces.
Some more construction details for ya'll - set neck and body laminates:
... and scarf joint:
Next up... its bondo time.  I'll fill any unneeded holes, and a couple spots on the edge where there was filler from the factory that the aircraft stripper disolved:
« Reply #46 on: August 29, 2009, 06:43:37 PM »
Give me a day or two Andy, I'll get you some shots.
Seeing as they're a different design, if you don't end up peeling 'em apart for another set of chrome covers they may be worth something more than a regular set at some point.
Hornisse
« Reply #47 on: August 29, 2009, 06:45:04 PM »
It is very interesting to see these basses nekked. :o  I spent some time today with my black one and it still amazes me.
« Reply #48 on: August 29, 2009, 08:13:27 PM »
Yes, indeed, very interesting!  So Bach is working smart - veneered core wood, most likely a mahogany sustitute - maybe african, maple neck with scarf joint.  I wouldn't call any of these things bad at all - this is still a great bargain.  Also, maple neck and mystery mahogany an everyone loves the way they sound.  If these Bach guys had a really sharp business manager they could really make some dough ;D
Oh, Chromium - don't forget the sanding sealer! It is your best friend ;)  I like the ReRanch spray stuff but just about any type will do.  This will give you an absolute dead smooth surface before you shoot your primer.  If you're already on to this my apologies :-[
« Reply #49 on: August 29, 2009, 10:25:09 PM »
That's cool- I ordered some of that.  Is it good to use that crosshatch pattern that John mentioned when leveling the s&s and primer coats?  or is that just recommend for the final wet sanding?  Their tutorial didn't speak to which sanding patterns to use (with the grain, crosshatch, etc...)
Here's a shot of my materials, in order of operations from left to right:
(bondo, grain filler, s&s, primer, ocean turquoise, clear, compound)
I'm still going to use the bartleys on the edges and the belly contour on the back.  The "mahogany" is very porous.  I'm not planning to use it on the maple, though.  Kinda relieved I won't have to do a lot of pore filling afterall!   ;)
« Last Edit: August 29, 2009, 10:33:40 PM by chromium »
« Reply #50 on: August 30, 2009, 04:09:09 AM »
The cross hatch is best after the wood is sealed, or primed once grain is not a factor.
« Reply #51 on: August 30, 2009, 07:37:35 AM »
I always spray vertically for everything, but flat for metallic makes sense (I haven't done one of those yet!).  I use naptha for wet sanding instead of water.  It works as well as water and won't crack any holes in the body.
« Reply #52 on: August 30, 2009, 08:56:43 AM »
Das ist richtig. Gut observiert.
Uwe, I love it when you talk German.  ;)
« Reply #53 on: August 30, 2009, 12:41:10 PM »
Yep, use your fancy sanding pattern once you're to top coats - I use kind of figure eight pattern myself.  The sanding sealer turns to dust the second you touch it with sandpaper - I bet 50% or more gets sanded off - it really helps getting the final few pores leveled off.
« Reply #54 on: August 30, 2009, 04:50:57 PM »
Thought I'd post some more pics along the way, for the benefit of any other newbies who may want to try this.  I have no idea how this is going to turn out! :o   Please let me know if you see me doing anything stupid!   ;D   (besides the obvious act of stripping a perfectly good guitar  ;D)
Did the bondo-ing last night, and block sanded it smooth today.  The screw holes (the original BaCH PG, TRC, tuners, and tailpiece) filled nicely, as did the couple of spots on the lower bout - were some factory filler had come out during stripping.
I tackled the pore filling this afternoon:
...wiping it on against the grain, using my fingers to work it in:
Man I can see where this would get tedious doing a whole guitar made of maho!
Here it is after the first coat, with the excess wiped off:
I'm going out now to apply the second coat, and leave it sit overnight.
Hornisse
« Reply #55 on: August 30, 2009, 05:13:30 PM »
Some nice grain on that Mahogany!
« Reply #56 on: August 30, 2009, 05:44:44 PM »
Deep joy, Joe... guess what my Thunderbird appears to be made of...   :o (Dave's advice is maho)
« Reply #57 on: August 30, 2009, 06:59:46 PM »
Looking good.  I despise doing grain filling - I curse myself everytime I do a project that requires it.  This is why most of my furniture builds are now cherry and maple ;D
BTW - I get my best results with grain filling using an old credit card.  Not to say that I still don't do a fair to middlin' job but for me credit card is the right size and stiffness
shadowcastaz
« Reply #58 on: September 01, 2009, 03:22:42 AM »
Tinted sheet rock mud is Much easier ,I must add, for grain filling. Nice to see her nekked though . Turquoise is your final color? Nice!
 I did a p bass and top coated with tinted nitro . Great color.
« Reply #59 on: September 01, 2009, 04:05:42 AM »
Fascinating to see. Will it eventually start growing leaves?
