Is 25% relative humidity ok? That's about what it is here now (and yeah- I'm in the outskirts of Phoenix, AZ). At what point do you risk getting a "cloudiness" in the finish? I should be okay on the wind. Dust is a b1tc4 here, but if the wind is calm I think I'll be okay.
Cloadiness is called "Blushing" it has a matt white finish/fog when it happens, but is not a big deal with a solid color nitro. Stew Mac sells spray blush remover, or you can lightly sand it out. You will know when it happens. 25% humidity should be fine.
If you get a spec of dust dirt or hair, stop immediately let it dry for sever hours and try to lightly sand it off and not pushing it into the paint. Same with bubbles. They look like tiny white specks in the pant. Usually is a sign of moisture. You have to sand the bubbles completely out.
With solid color nitro you can make tons of mistakes, sand them out & re-apply color as it melts in with the old. Very forgiving paint. The downside is it takes a long time (waiting for drying between coats). Reranch preaches the coats in 3s. lightly dust your first coat, then spay the next coats wet in three coats per application. Wait several hours between and do three more for a total of three applications a day.
By quality auto sand paper and I soaked mine overnight is a mixture of water & soft soap (removes grease, finger prints when sanding)
I use hard white styrofoam blocks to sand with as they will not dig into the paint, like a wood block will. Also sand in a cross patern so you level the surface and do not end up sanding ridges. Every mistake will be revealed with the final buffing, so get everything right before the paint. Sanding around the set neck sucks as you can't really do the cross pattern.
