Author Topic: I hesitate to post this. $45 Thunderbird pickups.  (Read 50894 times)
Re: I hesitate to post this. $45 Thunderbird pickups.
« Reply #255 on: April 06, 2016, 07:04:47 AM »
German pickup builder who also makes a Tbird repro humbucker
http://www.barfuss-pickups.de/bass-tonabnehmer/
« Reply #256 on: April 07, 2016, 07:23:50 PM »
That was a good description if you ask me! Thanks!
I'm planning to replace the original pickups in my '76 with these. Do I need rings or can I use the originals?
Also, as I have to change the wiring, what pots? 500 or 250 kOhms?
The China buckers come with rings and screws.  I use 500 Pham in the vol and 300 or 250 on the tone.  300 ohms are hard to find and cost double the 250.  I can't say I can hear a difference.
Pekka
    • Riverdog Samson
« Reply #257 on: April 07, 2016, 10:55:06 PM »
I ordered them without rings, there's an option at their site. Thanks for the potentiometer info, 500 and 250 it is then.
« Reply #258 on: April 08, 2016, 06:32:21 AM »
I used my Hagstrom 8 string last night at rehearsal, and under gainy settings the pickups were pretty prone to squealing. I've noticed they are also pretty microphonic, but they sound so good I don't want to pot them!
« Reply #259 on: April 08, 2016, 03:19:55 PM »
if the squealing stops when you put your finger on the pickup cover then gaffer tape on the inside of the cover may work.
veebass
« Reply #260 on: April 17, 2016, 07:46:22 PM »
I think I wrote here earlier that the bridge pup (nominal 9.2K) needed to be raised quite high to get a reasonable balance with a nominal 9.2K neck pickup. The pickup heights I settled with were- neck 8 mm below bottom of E string and bridge 10mm. Sounds great to me- just exactly what I was looking for.
The problem with this is the bridge pickup is almost out of the body and is a little unsupported, even with the chromed ring fitted. You can see the issue in this pic.
This worried me because the external wiring of the pickups is a little flimsy IMO (I had one arrive DOA because the external wiring was broken) and I didn't want to risk damaging the wiring by knocking the pickup sideways while playing it.
So I ordered some spacers from Thunderbucker Ranch. http://www.thunderbuckerranch.com/
Worked a treat- put one under the ring for the neck pickup and two under the ring around the bridge pickup- bridge pickup now solid as a rock. The spacers are ever so slightly smaller than the rings- I am guessing they are designed to go with genuine rings or the reissues that Thunderbucker Ranch sells- but no big deal. Well worth considering, if you go with these pickups.
BTW- I played her today after I finished installing the spacers and she sounds so great. Very happy.
Bionic-Joe
« Reply #261 on: May 16, 2016, 11:52:20 AM »
OK...I bought 2 nickel pickups...they have been sitting in Customs for 6 days now....is this normal????
« Reply #262 on: May 16, 2016, 12:26:36 PM »
how high is the g string off of that pickup?
veebass
« Reply #263 on: May 16, 2016, 10:12:12 PM »
Neck pickup minimum 2mm, bridge 4mm. I must have been having a senior moment when I measured the distances for my post above.  :-[
« Last Edit: May 16, 2016, 11:18:37 PM by veebass »
« Reply #264 on: May 17, 2016, 01:36:10 AM »
You could lower the bridge pickup slightly and use a trimmer internally to calm the neck pickup down a bit?
veebass
« Reply #265 on: May 17, 2016, 12:11:50 PM »
Yes or use the spare 8.2K one I have, which actually reads 8.5K, in the neck position. I like the sound of higher resistance one I have in the neck at present and the strings don't hit the pickups as I play, so all good.
« Reply #266 on: May 19, 2016, 11:44:10 AM »
I found a (new old stock) black BTH-1 for a customer of mine. Installed a repro humbucker and a custom pickguard.
This weekend its off to Spain.
    • Myspace page
« Reply #267 on: May 19, 2016, 07:28:51 PM »
Looks good with the black guard on there  :thumbsup:
« Reply #268 on: May 20, 2016, 02:15:54 AM »
Would that be a Blackbird? Stealthbird? I've never seen an all-black T-bird before, but that thing looks killer!
« Reply #269 on: May 20, 2016, 08:06:55 AM »
It's beautiful! Wow...
