1967 Guild Starfire restore
Started by shadowcastaz, April 22, 2008, 11:14:40 AM
shadowcastaz
I shoulda been a priest!........nah!
gweimer
The thing I love about disasters is the fact that you no longer have to worry about vintage integrity.  You have the freedom to do what you want on any level.
shadowcastaz
Lime and pink burst! Im on like a Ho on a hundred!Anodized orange tuners and a black bridge.
shadowcastaz
All patched and trimmed. Now the thumb sanding begins. :P
Very nice! How's the grain look in terms of matching?  I always find that's the real pain on a job like this.
shadowcastaz
Its ok..where the 2 meet In going to put a drop of crazy glue as I sand to fill a void if there is one. Then grain fill the patch (prob before i sand) and see then what happens . The danger of course is sanding through the old mahog and creating the problem again.Then Im gonna fool around with some test oieces  on the color. I gave an old mahog beater Im going to scab on some veneer  and  hit it w dye.I can make it opaque but I want the grain to show thru. I would never try to patch this amount and do a clear or light finish . Id stare at the mismatch all the time.
Makes sense.  Post a close up of the result.
bostonguitarrepair
I think you're going to have to subtly stain the patches - with some red in there it looks - so that the base color matches.  The transparent green is a pretty dark color though and I bet it will obscure a lot of the differences.
I'd use a darker grain filler so that the grain is visible through the darkish green tint -  ideally the filled grain should look like little black dots under the green finish.  But make sure any join lines are filled before applying the filler - cuz the filler will enhance those lines too otherwise.
Maybe this is all stating the obvious.
Krishna
Now that is one worthy resurrection. You'll go to Guild heaven for it no doubt.
Uwe
Yes he will!  This is the toughest type of woodworking in my estimation.  Repairing sand throughs like this is a real challenge.  If it were me, I would have been tempted to take the easy way out and fill as best as possible and paint it a solid color.  I give Mike a lot of credit for tackling this one.
shadowcastaz
#26
Back,not done fixin,
top with stain and  grain filler. gonna sand tonight I hope
Im gonna have to decide on opaque green or a natural reddish  finish ,that red residue is  a PIA!
Wow, that's looking really good!
You are a brave soul on this one.
Looking good!  I'm stripping my Guild now and tried chemicals on a section and the black residue bled into the maple a little, so I'm doing the rest with sand paper.  Chemicals are great, but they can create more problems than they solve!
bostonguitarrepair
Quote from: shadowcastaz on May 01, 2008, 09:32:00 AM
You need to get all that grain filler off the SURFACE of the wood - its a lot of hand sanding - I used a small rubber teardrop cross section sanding form I got at Rockler and it worked well.  I think it will look very good once you're done sanding off the excess filler. This looks almost exactly like what I went through with the Starfire I redid natural - see the archives or my website for pics of that process.
You will not get the red out of the end grain on the neck nor the sides - been there and tried that - as popeye would say "Imposski-bill!!!".
