Author Topic: Cheap Bass Strings  (Read 8966 times)
Re: Cheap Bass Strings
« Reply #45 on: April 28, 2009, 06:51:59 AM »
Jamerson would be proud Pilgrim.  ;)
« Reply #46 on: April 28, 2009, 07:59:45 AM »
What Pilgrim hasn't told you is how many years that bass sat without being played.  8)
Come on, Al, fess up.
« Reply #47 on: April 28, 2009, 08:41:09 AM »
Geez, I'm proud n'humble.  But Dave has a great memory - the bass mostly sat in its case between 1973 and 1997.  I know my younger brother played it a bit in the 70's, but how much I dunno.
I will say that since I like the sound of this bass with these strings, I've decided that strings are forever until they break.  If I like 'em, I just keep 'em on.
Here it is.
Here's the headstock - and yes, you purists, it's not a '63 neck, it's a '72 neck because the truss rod broke in the original neck, and I had to re-neck it for a gig the next day.
Anyone know what brand of flats used this color of silk wrapping back in the late 60's / early 70's?  They seem to last pretty darn well!
« Last Edit: April 28, 2009, 08:57:32 AM by Pilgrim »
« Reply #48 on: April 28, 2009, 09:54:50 AM »
Could they be GHS Precision Flats? They've had purple silks for years, but I don't know if they did back then. Company's been around since the mid 60s, IIRC.
No matter what kind or brand, I keep strings on until I think they sound bad or until they won't intonate properly.
« Reply #49 on: April 28, 2009, 03:21:48 PM »
I think I have some GHS flats on a Lyle SG-style...I'll take a look.
« Reply #50 on: April 28, 2009, 03:45:12 PM »
Strings may come and strings my go but flat-wounds just don't do it for me...
I've errr... broken quite a few... but I always keep any halfway decent old strings, just in case...
« Reply #51 on: April 29, 2009, 05:18:16 AM »
I have never broke a string, how do you achieve that guys? I mostly use fingers but sometimes I use a pick. Should I start using knife blades or something? :P
« Reply #52 on: April 29, 2009, 06:17:52 AM »
I've never broken a bass string either. Guitar strings are a different story.
« Reply #53 on: April 29, 2009, 02:24:38 PM »
I used to break either an A or an E about once a month for ages after I bought the Jazz before finally learning that the guy who had filed the grooves in the Badass saddles had made them too sharp. Had them modded and haven't broken a string in more than 20 years.
« Reply #54 on: April 29, 2009, 03:04:56 PM »
I led a dubious life playing mostly in three piece with vocals, playing a lot of chords to fill in during solos (the Hiwatt is handy for that as she has a built in volume switching circuit) and tended to be a bit rough so they tended to deteriorate quite quickly... that and the Tequilabird had a Badass bridge and pointy saddles...
My last band in the 80's (now re-formed) was/is much more restrained and I mostly play with my fingers these days...
I also discovered some oddball Rotosound strings which had the core exposed to go over the saddles - exceptionally bright but highly fragile - don't use them now although the Hohner still has three... as I said, I don't change them unnecessarily... though nothing as old as Pilgrim Al's ...  ;D
« Reply #55 on: April 29, 2009, 08:22:39 PM »
I checked the bass with the GHS strings (as far as I can recall). The silks are a dark purple and the windings on the old flats on that P-bass are closer to blue.  I don't think they have been exposed to enough light to fade to blue, so either GHS changed colors or it's some other brand on the P-bass.
« Reply #56 on: April 29, 2009, 09:11:18 PM »
If it's any help, all sizes of LaBella flats had royal blue silks back then.
« Reply #57 on: April 30, 2009, 07:21:18 AM »
AHA!!!  Justified or not, that would reinforce my faith in LaBellas, my favorite flatwounds.   ;D
