Yesterday I just finished the shaping of the second body and called it a day, hardly worth an update.
Today I played around with the neck joint, I made a quick MDF jig to cut the tenon on the router table and screwed it to the top of the neck along the centreline where the truss rod will be set in next week. I roughed out the tenon on the bandsaw and routed the neck. They turned out just a tad tight so a couple of wipes with a file saw them a perfect fit. Then I semi scribed them into the body but left the tenons needing to move forward by about 1mm when the neck has had some shape cut into it so by scribing the neck join this will pull in nicely. I did the rough scribing with a dovetail saw and then pared off anything that looked to be sticking out. The tops of the necks are still about 3mm proud of the surface of the body, I'll sort that out next week after thinning just to make 100% sure everything stays straight and flat
So for now we have two massive blanks for the necks waiting to be thinned and the scarf joints cut for the angled headstock will probably do that on Sunday, I have other things to do until then unfortunately
And for those who have been wanting to see what I keep in my drawers
