The Badbird II has landed!
Started by godofthunder, March 22, 2016, 08:09:22 AM
   It's here! Installed on my 2001 Gibson Thunderbird.  Works great very pleased with the end product. I can't post pictures from my phone 😕 and my pc and photo bucket are not cooperative.  Maybe someone can grab some pictures from my fb page?
That does look nice.  Looks like it can go quite a bit lower than an actual 3 point.
Defender of the Holy Immaculate Trinity as I am, this does look good indeed. Gut gemacht, Scott!
Quote from: Granny Gremlin on March 22, 2016, 09:10:58 AM
You can definitely get the action super low, much lower than the original  three point.
I'm happy for you that it turned out so well. Hope it sells for you.
neepheid
If it can get down lower than the original 3 pointer then I may well be tempted to try one (minus the tailpiece) on my Ripper - the three pointer is pretty much on the deck but I think I would still like it a bit lower yet.
A beautiful and more functional piece of hardware!  Nice job Scott.   :thumbsup:
Quote from: neepheid on March 23, 2016, 04:55:01 AM
Your saddles are too high then, probably the vintage type they originally used on the three point.
#9
Quote from: uwe on March 23, 2016, 10:39:02 AM
Those early 3-points I've had used two *really tall* saddles in the A&D slots, and that narrow radius it creates makes it hard to get a good setup.
I usually reorder the saddles so that the two highest ones sit under the E&A string, and the two lower ones are in the D&G slots... and then tilt the base accordingly using the outer studs.  Wonky? Yes!
Here's one I did last night.  Might shim the D up just a bit, but otherwise it setup nicely after "the tilt":
And back on the Badbird subject, that looks mighty fine.  Congrats on your accomplishment, Scott!  8)
Those saddles don't look right. That notch on the G saddle looks way too wide.
And the saddle heights look like a mess too.
Quote from: Basvarken on March 23, 2016, 04:10:50 PM
There is slop in the G notch, but surprisingly it doesn't cause me any grief with the center screw hiked up a bit. I like it better than the stock saddle arrangement- since the radius imposed by the saddles doesn't jive with the radius of the board (A&D string action ends up noticeably higher).  Other option would be to cut the A&D notches extra deep, but that ends up looking goofy too...
I tried a set of newer saddles on a 70s bridge recently.  They fixed the radius issue on those, but I had to shim the bottoms of each so they would seat correctly in the older base.
Quote from: chromium on March 23, 2016, 04:37:17 PM
Just ditch it and buy a Badbird II.  :)
Vile propaganda by a man with a two-point apologetic track record.
Quote from: uwe on March 23, 2016, 04:53:52 PM
I've heard that North Korea is desperately short of pot metal and that Kim Jong Number Un has demanded that all Gibson and Epi three-point users turn in their bridges to be melted down.  :P
