Author Topic: The Badbird II has landed!  (Read 5756 times)
« on: March 22, 2016, 07:09:22 AM »
   It's here! Installed on my 2001 Gibson Thunderbird.  Works great very pleased with the end product. I can't post pictures from my phone 😕 and my pc and photo bucket are not cooperative.  Maybe someone can grab some pictures from my fb page?
Re: The Badbird II has landed!
« Reply #1 on: March 22, 2016, 07:39:58 AM »
Looks great man!
« Reply #2 on: March 22, 2016, 08:10:58 AM »
That does look nice.  Looks like it can go quite a bit lower than an actual 3 point.
« Reply #3 on: March 22, 2016, 09:04:40 AM »
Defender of the Holy Immaculate Trinity as I am, this does look good indeed. Gut gemacht, Scott!
« Reply #4 on: March 22, 2016, 09:38:18 AM »
You can definitely get the action super low, much lower than the original  three point.
« Reply #5 on: March 22, 2016, 02:38:39 PM »
I'm happy for you that it turned out so well. Hope it sells for you.
neepheid
    • The Inevitable Teaspoons
« Reply #6 on: March 23, 2016, 03:55:01 AM »
If it can get down lower than the original 3 pointer then I may well be tempted to try one (minus the tailpiece) on my Ripper - the three pointer is pretty much on the deck but I think I would still like it a bit lower yet.
« Reply #7 on: March 23, 2016, 04:33:41 AM »
A beautiful and more functional piece of hardware!  Nice job Scott.   :thumbsup:
« Reply #8 on: March 23, 2016, 09:39:02 AM »
Your saddles are too high then, probably the vintage type they originally used on the three point.
« Reply #9 on: March 23, 2016, 02:17:52 PM »
Those early 3-points I've had used two *really tall* saddles in the A&D slots, and that narrow radius it creates makes it hard to get a good setup.
I usually reorder the saddles so that the two highest ones sit under the E&A string, and the two lower ones are in the D&G slots... and then tilt the base accordingly using the outer studs.  Wonky? Yes!
Here's one I did last night.  Might shim the D up just a bit, but otherwise it setup nicely after "the tilt":
And back on the Badbird subject, that looks mighty fine.  Congrats on your accomplishment, Scott!  8)
« Last Edit: March 23, 2016, 02:23:39 PM by chromium »
« Reply #10 on: March 23, 2016, 03:10:50 PM »
Those saddles don't look right. That notch on the G saddle looks way too wide.
And the saddle heights look like a mess too.
« Reply #11 on: March 23, 2016, 03:37:17 PM »
There is slop in the G notch, but surprisingly it doesn't cause me any grief with the center screw hiked up a bit. I like it better than the stock saddle arrangement- since the radius imposed by the saddles doesn't jive with the radius of the board (A&D string action ends up noticeably higher).  Other option would be to cut the A&D notches extra deep, but that ends up looking goofy too...
I tried a set of newer saddles on a 70s bridge recently.  They fixed the radius issue on those, but I had to shim the bottoms of each so they would seat correctly in the older base.
« Reply #12 on: March 23, 2016, 03:41:28 PM »
Just ditch it and buy a Badbird II.  :)
« Reply #13 on: March 23, 2016, 03:53:52 PM »
Vile propaganda by a man with a two-point apologetic track record.
« Reply #14 on: March 23, 2016, 08:40:49 PM »
I've heard that North Korea is desperately short of pot metal and that Kim Jong Number Un has demanded that all Gibson and Epi three-point users turn in their bridges to be melted down.  :P
