Author Topic: Repairing EB-0 headstock crack  (Read 8381 times)
« on: June 22, 2010, 07:42:47 PM »
What I have is a '64 EB-0 with a G-string tuner area headstock crack, (perhaps 2 or three) but not a full headstock break.
It doesn't look like it's going to be too difficult to repair, but I sure want to get it right the first time...don't want to deal with glue from a failed repair.
I'm thinking:
1) Remove tuners
2) Evaluate clamping areas - make cauls to fit if needed...this looks like an almost flat clamping area, although it extends below the headstock a bit.
3) Use syringe to inject copious amounts of Titebond (original) throughout cracked areas
4) Clamp, wipe and be patient for 24+ hours.
Suggestions, comments, encouragement?
Dr. Aquafresh
Re: Repairing EB-0 headstock crack
« Reply #1 on: June 22, 2010, 08:28:39 PM »
Looks like a pretty straight forward repair, seems to be a common issue with the beloved Gibson. In the plus column, it will never break there again after you repair it right.
Not that I am recommending it but you may want to keep an open mind about not breaking it off all the way and then re-gluing it. Of course, I'm not looking at it so I cant say for sure. Lots of good info on the web that may be helpful to you. I'm sure you have done a lot of homework already.
I bet it's going to be great when it's all said and done.
Bring on the Nubiles
Dr. Aquafresh
« Reply #2 on: June 22, 2010, 08:35:34 PM »
Here is one that looks a little like what you got, looks like they were able to do it with out having to snap it all the way off.
http://www.timeelect.com/headstock.htm
« Reply #3 on: June 23, 2010, 07:19:02 AM »
As you say, I've been doing some looking for repair techniques - I found that link and they did a superb job.  I thought about that, and checked ReRanch - they do sell the Gibson cherry lacquer in a rattle can at $16.  Makes it not worth firing up my air compressor and airbrush.  The critical part is getting a perfect glue joint - I'm not scared by the touch up/refin afterwards.
I'm also considering having a luthier do it - but if I throw in $100 there, then a pickup, then a bridge, the price starts to get high.
I'll be interested to see what comments I get.  I won't have a chance to get into the crack and really check it out until this evening or tomorrow evening.
« Reply #4 on: June 23, 2010, 08:51:24 AM »
Your approach is perfect ! Go for it !
« Reply #5 on: June 23, 2010, 11:16:40 AM »
Al, I would clamp the top of the headstock ina vise, and gently pull on the neck to open the crack a little and take a good in there.  If you see lots of raw wood and no major signs of old glue, then injecting it is exactly what I would do.  If you see lots of old glue, then the Titebond may not hold properly.  Then you have to consider how cleaning it out might go for you.
« Reply #6 on: June 23, 2010, 11:18:50 AM »
Al, I would clamp the top of the headstock ina vise, and gently pull on the neck to open the crack a little and take a good look in there.
...and hopefully not hear a loud crunch, right?   :o
That seems like a decent idea to get a look at what the situation is.
« Reply #7 on: June 23, 2010, 11:28:40 AM »
Have a magnifier and bright light handy when you do it!  Just don't get too aggressive!   :P
« Reply #8 on: June 23, 2010, 11:40:28 AM »
Good point Bill ! I was thinking that it hadn't been repaired.
« Reply #9 on: June 23, 2010, 11:45:06 AM »
My concern is (what looks like) the two cracks (hopefully in the fin) that extend under the tuner and cross the primary crack - the two I had in the neck of the PC turned out to be only in the fin, but no way of knowing for sure until I stripped the fin...
Other than that, looks like a fairly straightforward job... (fin-gers crossed)
« Reply #10 on: June 23, 2010, 01:46:15 PM »
I'm 90% sure it has not been repaired, but there's always room for surprises.  No external evidence of a repair at all!
« Reply #11 on: June 24, 2010, 05:15:06 AM »
That's positive!
« Reply #12 on: June 24, 2010, 06:33:27 AM »
Go for it.  Original titebond is only recommended for perfectly mated surfaces.  According to the mfr. it has zero strength in filled gaps, so you might research other options.  That said, I have used it in less than perfect situations and it's always worked.
The possibility of multiple cracks would have me a little concerned, I'd try careful clamping dry first with minimum pressure to get a better idea of the situation.
I don't mind seeing the scars of a properly done repair, to me it looks better than an almost opaque layer of toner.  I'd airbrush vs rattlecan for something like that, you have a lot more control.
« Reply #13 on: June 24, 2010, 08:32:08 AM »
Stew mac has some thinner faster drying glues that worked pretty good for a few neck repairs i have done although non were that bad.  they aren't cheap but have seemed to work well for me.
« Reply #14 on: June 24, 2010, 12:13:30 PM »
Stew-Mac carries good stuff. Interesting note on the Titebond. I'll see how closely I can mate the sides of the break. If in doubt I'll consider an epoxy, but I sure like the easy clean-up of wiping off Titebond.
