Author Topic: Greco Single Pickup Thunderbird bass craigslist  (Read 18237 times)
FrankieTbird
Re: Greco Single Pickup Thunderbird bass craigslist
« Reply #75 on: January 26, 2010, 08:11:13 PM »
Congrats! Great shots. Is that a three point on that Embassy?  :o
Yeah, the Embassy has a 3-point bridge on it, but only has the two original mounting studs.  The front of the bridge is just resting on the wood.  That's the way it was when I bought it.  I suppose I'll eventually get around to fitting a proper 2-point bridge on there, but it works just fine the way it is now.  I have to admit I don't much like the looks of it myself.  Will probably fit a 2-point to the Greco at the same time I do the Embassy.  Has anyone had any luck buying the T-Bird bridges from Bach?
« Reply #76 on: January 26, 2010, 08:13:10 PM »
Now where can I get a proper stand for a Thunderbird?  ;D
You need a hanging/grab stand like the Hercules.
FrankieTbird
« Reply #77 on: January 26, 2010, 08:14:33 PM »
Lovely basses all!
 I'd enjoy your opinion of the Greco vs that gorgeous '64 ( I'n soooooo jealous!) 'Bird.
Glad it went to a good home too  ;)
Thank you, sir!  I'll try to post my views once I get a little more playing time in with it.  I can tell you right now, the Greco neck is quite a bit wider at the nut than the Gibbo, which I'm not wild over, but it still feels OK.  Nice low action too.
FrankieTbird
« Reply #78 on: January 26, 2010, 08:16:03 PM »
That sounds like it would work well, although it would have to be about four feet tall!
    • Myspace page
« Reply #79 on: January 26, 2010, 09:21:42 PM »
I have a couple of stands with the swivel bottom. Works great for T-birds.
« Reply #80 on: January 26, 2010, 10:34:24 PM »
The Hercules are height adjustable and hold Birds just fine.
Stjofön Big
« Reply #81 on: January 27, 2010, 03:15:51 AM »
Well, well... That sure is one nice collection! And congratulations to that Greco. Looks just fine! I hope you will give us your impression of the pickup too!
ramone57
« Reply #82 on: January 27, 2010, 05:43:49 AM »
nice basses!  as already mentioned, either the hercules or a swivel bottom stand will work just fine.
« Reply #84 on: January 27, 2010, 09:20:15 AM »
Cheaper than this one, and better knobs.
http://www.gbase.com/powered/geardetails.aspx?dealer=d02a9c2b-5538-4fca-8368-7d1c15b78d13&item=2059240
"Manufacturer: Ibanez for Greco"  :rolleyes:
NOT! Ibanez has never been a manufacturer. But we've been over this before.
« Reply #85 on: January 27, 2010, 07:32:27 PM »
You need to talk to Scott, aka God of Thunder, here - he makes a vastly improved two pointer that should drop right on to your studs.
FrankieTbird
« Reply #86 on: January 28, 2010, 04:47:44 PM »
As you can see in the headstock shot of the Greco, it's missing the tuner bushing for the E-string tuner.  Anybody have one they can part with?  The tuner shaft is 11.5mm, and the hole seems to be about 15mm.
« Reply #87 on: January 28, 2010, 05:07:28 PM »
I have some Allparts tuners with bushings. Let me check tonight and see if they're the right size. If so I'll send you one.
FrankieTbird
« Reply #88 on: January 28, 2010, 05:13:13 PM »
Thanks OMC! :toast:
