Incoming ABG- Stu Hamm sig Washburn AB40SH
Started by dadagoboi, July 06, 2015, 10:39:07 PM
Serial #1, with any luck it will be here Friday.
Nice... still got the protective plastic on the machines...
Never really been played, has an authentication document...let's hurt it!
Quote from: Dave W on July 07, 2015, 10:25:19 PM
Nice score. I never knew these existed.
Me either, Dave.  Apparently not for very long, it's a 2014.  There's a similar model now but not as snazzy.  I was looking for an AB-20 but this seemed too good to pass up.
Interesting bass with individual level controls per string!
Quote from: Basvarken on July 08, 2015, 05:25:50 AM
My piezo equipped Godin has them but they're inside the cavity.  On the cover is a much better place IMO.
Gibson had these as early as the mid-eighties with their Shadow Piezo basses (Explorer and Q-80). They make utter sense - on an acoustic bass guitar, different string loudness levels can drive you (or at least me!) nuts and it happens quickly if string to bone saddle pressure isn't even. That can cost you hours of trial and error padding of the piezo strip from underneath to equalize the different pressure levels, taking off the strings everytime.  >:( Even on recordings I all too often hear acoustic basses where the piezo string levels are uneven. And it's not something you can hide with equalisation either.
I still play my trusted AB-20 frequently at home, I have better acoustic basses (Martin and Höfner) with better (more advanced) Piezo systems, but the AB-20 is probably the bass I do the most composing on.
I remember that Explorer Shadow sounded great and much warmer than you'd expect from a bass with only a piezo pickup.
Most acoustic guitar or basses sound like someone put a cigarette rolling paper between the strings; that annoying ravelled sound.
The Explorer Shadow didn't have that at all. Right?
Take it to the Bridge(s), finally a sensible piezo solution.
This is what I'm playing until it arrives, my modded $20 Chinese 'ThundaCoustic' with '67 TBird pickup.  I used the rail bridges before I even knew the SH existed.  32" scale.
No battery needed.
Sounded Thunderous last night!
Quote from: Basvarken on July 09, 2015, 02:40:17 PM
True, it sounds surprisingly warm and fuzzy. The piezo just shows its inherent drawbacks with the dynamics, play too hard and the signal distorts nastily.
carlo, what kind of amp are you playing through?
Quote from: nofi on July 10, 2015, 10:10:03 AM
'64 B-15, '13 Genz Streamliner 900 thru a 67 B-15 cab with eminence legend 8 ohm or a  Carvin 1-15 cab with  a 4 ohm 300 watt Eminence or all that stuff plus a 200 watt Ampeg  B-1 head.  So far I've only used the B-15 with it but I'm liking the sound.  It arrived at 12 and I went to friends' for dinner at 1.  Just back and ready to tinker.
