Author Topic: Speaker jacks  (Read 2696 times)
Happy Face
Speaker jacks
« on: June 10, 2015, 06:24:15 AM »
I'd like to keep using the old 2x12" cab I put modern speakers into. It only has a phono input.
But two of my amps only have speakon outputs. Some folks swear that you need 'em for high power amps but a couple sound guys I know say they are just an unnecessary PITA.
I have converter jacks but was pondering putting in a speakon input into the old cab.
Question for wiser folks: outside of the locking aspect, what's the difference between putting in a speakon input and using a converter jack? Is the wiring off of the backside of the speakon input jack any different than that on a phono jack?
Hope I'm being clear with my question.
« Last Edit: June 10, 2015, 07:18:26 AM by Happy Face »
Re: Speaker jacks
« Reply #1 on: June 10, 2015, 06:45:06 AM »
No.   Speakons are 4 pole for biamping, just use 1 and 2 IIRC.
You can get locking phone jacks if you like that feature.  They have a release tab that's easier to use than the twist off speakon IMO.
Re: Speaker jacks
« Reply #2 on: June 10, 2015, 08:09:40 AM »
+1: Speakon is more chunky, more annoying, and more expensive.
Re: Speaker jacks
« Reply #3 on: June 10, 2015, 08:18:24 AM »
I think all cabs should have a 1/4'' jack on them. Speakon - fine. But if you're in a bad situation, you're going to have a much easier time finding someone with a spare 1/4'' to 1/4'' than a Speakon of any kind. My custom built cab has a locking 1/4'', and a Speakon.
Re: Speaker jacks
« Reply #4 on: June 10, 2015, 09:08:40 AM »
I agree. My Genz cabs are speakon but my backup cables are all 1/4", so I carry a couple of speakon>1/4" adapters just in case.
Re: Speaker jacks
« Reply #5 on: June 10, 2015, 11:26:15 AM »
I hate Speakons.  Does that help?   :sad:
Re: Speaker jacks
« Reply #6 on: June 10, 2015, 11:44:41 AM »
I like speakons.
They are more secure than the wobbly connection of a jack.
Especially when it comes to transferring the hundreds of Watts from a tube amp to a cab, you don't want to take any chances.
I don't see what's so difficult about the slide and twist of a speakon connection.  :sad:
Re: Speaker jacks
« Reply #7 on: June 10, 2015, 04:17:45 PM »
Re: Speaker jacks
« Reply #8 on: June 10, 2015, 04:29:14 PM »
I can't get at the cab at present as it's buried in the packing boxes but I used XLR's on mine, but in a different fashion...
As I had a pair of new 75w speakers and a pair of '69 Celestions that still (just about) worked in my 4x12 I wired one XLR for each pair, plus a third with all of them, noting the different ohmage values for each input...
Cut an image from one I had on file...
Happy Face
Re: Speaker jacks
« Reply #9 on: June 10, 2015, 07:10:03 PM »
How about the best of both worlds?
http://www.neutrik.com/en/speakon/speakon-chassis-connectors/speakon-combo/
Thanks everyone. Maybe our Antipodean friend has the best solution? I know that adapters love to pick up and hide themselves in the bottom of my gear bag or in a pocket where totally unrelated gizmos hang out.
Re: Speaker jacks
« Reply #10 on: June 11, 2015, 04:57:06 AM »
I wonder why they didn't design Speakon jacks like that from the outset.
Re: Speaker jacks
« Reply #11 on: June 11, 2015, 07:45:22 AM »
I thought they were when I first saw them.  Very disappointed when I tried to stick in a phone plug!
Re: Speaker jacks
« Reply #12 on: June 11, 2015, 08:09:26 AM »
Re: Speaker jacks
« Reply #13 on: June 11, 2015, 09:58:04 AM »
See my earlier post.
$10 each.
FrankieTbird
Re: Speaker jacks
« Reply #14 on: June 12, 2015, 10:08:38 AM »
I have had 1/4" plugs blown right out of the jack in the speaker cab from the sound pressure waves.   I'm sure others have also.  Not the best thing for a tube amp.  Don't have much experience with Speakons so nothing to add there.
