A couple basses finally ready
Started by drbassman, April 23, 2015, 01:48:50 PM
Huge disappointment today.  :-\. Started installing hardware and the clear coat is chipping off every place there's an edge, like tuner holes, control pot holes, neck pocket.  Gonna contact the finisher to see what's up.  The clear is a catalyzed lacquer and it isn't sticking to the paint coat at the edges.  What's up with that?   >:(
I believe "bummer" is the correct vernacular for you Colonial types... :-\
I'm keeping my fingers crossed as that's what I've just used on my RD... :o
Correct, humongous bummer.  It's weird Kenny.  The clear isn't sticking to the undercoat at the edges.  Never seen anything like it.
I have... a similar weakness appears to be present in the PC's fin, which is something I've yet to consider... at least, in my case, it shows mojo, but not for a new work such as yours...
Carlo, Rob, Joe, Brad, et-al... opinions...?
Sounds like something in the prep stage may have been missed. OTOH I don't know how catalyzed lacquer is supposed to be prepped.
Just at a curing catalyst and use promptly - just like any two-part mix - the stuff I used on the RD (acrylic) came in a rattle-can and you just had a separate plunger in the base - "crack" the seal, shake for 2 minutes, rest for 10, use within 6 hours... checked mine this morning and it looks like I'm a goer for polishing... no tackiness and it feels "set"...
The nitro. again rattle-can, I used on the AD was "pre-cat" so presume the reaction is once in contact with air... that had the last coat yesterday afternoon and feels same as the RD...
Hope all works out for everyone.
IMO the best bet  for a successful paint job is to make sure the various layers are compatible and correctly prepared to bond with each other.  For example, I've had problems with clear nitro lacquer over acrylic lacquer.  The nitro shrinks, the acrylic doesn't and cracks are the result.
What's important is the actual chemistry of each component, no matter what the front of the can says.  Most times you have a better chance of success using one manufacturer's products from start to finish.
I agree with you Carlo.  Something isn't right with the base and the top coats.  The top just isn't sticking to the bass as it should.  We'll see what he says, going call him later this morning.  I sent a text and no reply.  I hope he's not avoiding me!
Send the boys round, Bill... either that or a fish wrapped in old newspaper... :vader:
Took the bass over to the finisher and we fixed it.  The big issue is the stuff goes on pretty thick and all of the holes have to be cleaned out carefully.  Got a quick lesson on that and I think we're good now.  Fixed the couple chips with CA.  I love the finish, but I'm still not impressed with the edges around any holes.  A bit too delicate there for my liking.  I'll have him do a couple more and if it's a continuing issue, I might seek out another source.
shadowcastaz
Doc, been a long time . I love the fact that you are doing what you love . The logo is awesome. Cant wait to see the finished piece.M
Definitely a bummer, and a big +1 to following the manufacturer's finishing schedule recommendations.
Basecoat/clearcoat systems can be very finicky, and it seems as though there are infinitely many ways to mess things up.
Quote from: shadowcastaz on May 20, 2015, 09:26:48 PM
Hey Shadow, great to hear from you!  Yeah, I'm working toward my hobby shop and a second retirement.  I'm seriously thinking about packing in the work gig January 1st.  Then I can build full time and goof off in between!   How have you been?  ;D
Quote from: BeeTL on May 20, 2015, 10:21:17 PM
For sure.  I have a better understanding of how his system works and I think it will be OK for me.  I did mess up the finish installing a tuner, so the neck goes back to him early next week.  Ugh.  The body, however is almost put together.  Slow but determined I am!
OK, I'm still assembling #1 but #2 is back from the finisher.  It's all done except for headstock logo.  I've had a logo fail and need to order some new ones.  Once I get them, it will be applied to this bass.  This is the cherry top and back with mahogany sides, mahogany neck.  I might have a hard time letting this one go!
