Ah, Pandora's box....
Started by drbassman, February 24, 2015, 08:44:21 AM
OK, the jack on my Kubicki has been acting up.  The problem with the though-body jacks is their enclosed case.  You can't tighten up the plug clip when it gets stretched.  I like using them, but they do wear out.  Of course, I decided to check it out and several fun things appear.  First, the electronics, ala NASA, are crammed into the cavity with zero tolerance.  I had to remove all of the circuitry guts just to get at the bottom of the jack.  The guess what, one of the jack wires broke off the circuit board (a tad brittle after 20+ years).  Not a big deal, just annoying.
So, I ordered a new through-body stereo jack.  It needed it anyway.  When it arrives, I'll be back asking for pointers on wiring my first ever stereo jack.  I'll probably go with new wires for the jack to circuit board run.
The biggest pisser about this is I was going to take it to practice tomorrow.  Oh well!  :-[
Quote from: drbassman on February 24, 2015, 08:44:21 AMThe guess what, one of the jack wires broke off the circuit board (a tad brittle after 20+ years).  Not a big deal, just annoying.
Of course it did! Sounds like my luck. I'm not a fan of those barrel jacks either.
Quote from: gearHed289 on February 24, 2015, 09:32:51 AM
Yeah, barrel jacks!  Couldn't think of the term on my own.  I'm dying to play this bass but have to wait for the parts now.
If something bad can happen, I can usually count on it.  Comes with the territory of tinkering and fixing things myself.
Ah, grasshoppa, remember no good deed goes unpunished.    :P
Quote from: Pilgrim on February 24, 2015, 11:32:33 AM
For sure, Al.
I went XLR decades back... never had a failure... ;)
Quote from: drbassman on February 24, 2015, 08:15:28 PM
XLR?
These:
By barrel jack do you mean these:
If so then note that the lower end Neutrik ones (aka REAN) are notoriously unreliable.  Spring the extra bucks for the Switchcraft ones.  I use them in speaker cabs and learned the hard way - sometimes even new, the Rean/Neutriks just don't work right.  Which is odd because all their other stuff is rock solid (I use Rean RCA jacks all the time; best quality:price ratio).  If I was a bit more pessimistic I'd posit that they did that intentionally to get folks to switch over to speakon, but it's more likely that it was just due to factory change/offshoring.
Interesting.  The issue might be the space provided for the jack is limited and these might be too large.  I'll do some measuring to see.
I assume you can wire the cable to go from XLR to a 2 conductor 1/4" cable that plugs into the amp jack?
steveonbass
I repaired a Kubicki jack once for a good friend and the EXACT SAME THING happened.  I re-lived all the horror again just now.
Mics tend to use XLR plugs as their connector and as a three pin they are stereo capable as an option with a three core flex... came as standard on Alembic, iirc...
I like them because the are locking connections and I get very little noise issues... I have/had them on cabs too... adaptors are multi-choice...
Quote from: drbassman on February 25, 2015, 12:30:32 PM
You can buy xlr to 1/4" adaptors, just make sure the one you buy is for instrument cable.
Quote from: Dave W on February 25, 2015, 04:09:13 PM
Less than $5 delivered on Ebay
Quote from: steveonbass on February 25, 2015, 02:14:45 PM
It's always something!  I like the XLR idea but I don't think there's enough room for the jack.
steveonbass
FYI: Phil Kubicki is a pretty accessible guy if you reach out.
