Reproduction NR Thunderbirds
Started by godofthunder, February 07, 2015, 02:40:39 PM
   I am in the process of producing a very accurate Non-reverse reproduction, all mahogany construction, set neck the works. Watch this space for updates.  ;)
66Atlas
Scott, I wish you the best with this project. You'll do it right.
Finally! It has always bugged me that BaCH ignored some of the specs I gave them.
Hell, even Gibson managed to screw it up!
Now is the chance to do it right. Got for it Scott!
There are several pickup builders that make the Thunderbird humbuckers. Jason Lollar makes them too. But there is also a guy in Germany called David Barfuss. He makes a reproduction of these pickups too. https://www.facebook.com/david.barfuss.12
Good luck, Scott!
This begs the question, "how accurate to the originals were the 30 BaCH Series IIs?" Mine seem pretty darn close to my original one.
There is always room for improvement in the smaller details Denis.
The headstock should have had a lightly slanted edge. The control cavity on the BaCH shouldn't have been triangular. The pickguard of the BacH was just plain wrong. The tailpiece shouldn't have been straight forward rectangular, but rounded off. The knobs shouldn't have been in equal distance to another. The machine heads should have had the accurate shape baseplate (such as the Gotoh resolites). And BaCH forgot the bellycut on the back.  ;)
Bring it on, Scott. ;D
I know you'll do a great job!
Bionic-Joe
Bro....You have to make at least one that is all Korina, with an amber Nitro clear coat, parchment guard!!!!!!! I always dreamed of making one myself.....
  The Bach series II were very close, certainly better than Gibsons attempt. I love my Series II and two series III , once tricked out they give my real ones a run for the money but they are not  100% accurate. Things like the veneer over the top and back of the body, poly finish, pickguard, changing body shapes and thickness etc. are just some of the things not right.  I plan on using Thunderbucker pickups as long as Steve is still winding them. I was going to cheap out and do bolt on but I think a set neck is a must.  I have no intention of fixing the quirks associated (like neck dive) with NRs. I will build to sell at first then after I am satisfied with the process I'll build to order. I am using on of the suppliers the big guys use so it will be consistent CNC quality and I have (Bill found him) a local guy who shoots lacquer and does great work lined up for finishing.
QuoteI was going to cheap out and do bolt on but I think a set neck is a must.
Absolutely. A bolt on for a NR Tbird doesn't make sense to me.
Quote
Gotoh Resolites will fix that for ya.
Scott, you're the right man to do this. I wish you much success in a most worthy endeavor!
I can feel the temptation already.
Quote from: OldManC on February 08, 2015, 11:17:43 AM
Yep, couldn't say it better!
