Difference(s) between the SG Std & SG Special ?
Started by ack1961, December 12, 2014, 10:32:02 PM
ack1961
I know absolutely zero about Gibson basses, but I'm curious because I see the 2014 SG Std listed for ~$1500 and the SG Special (w/ Gibson HSC) for <$700.  I see inlay and finish differences - anyone know any major differences and have any experience with the 2014 Special?
Thanks,
Steve
Not sure about that one, Steve, but my '74 SG Special (sixer) meant budget version... single ply scratch, mini pups, basic fin, plastic faced headstock, and a Bigsby (clone, stamped Gibson)... pickups are just plain mean, and by that I mean off or KILL... absouletly gorgeous rock sound and same for bottle in an E tune situ...
The 70's special guitar was circa half price and not a perfect instrument, but... presumably something similar...?
Mine's presently (sort of) bare timber, and has been for a couple of decades (including headstock face) and she's all mahogany and ebony... presume just cheaper cuts, but...
Someone will be able to offer a direct comparison sooner or later... a very "sixties" shape bass but still a popular "guitar"...
Mind you, a "P" is a very "fifties" shape, if you get my drift...
Beauty is in the eye of the beholder...
You could possibly get a long scale, set neck, Epi SG bass for half the price of the "Special", if the shape fits, that may be just as good... may be... ;)
My Squier Jazz is as good as many Fender's I've tried...
Quote from: ack1961 on December 12, 2014, 10:32:02 PM
Thanks,
Steve
A good finish alone may explain the $1500 price tag, that's Gibson in a nutshell :-\
ack1961
Thanks for the replies.
I couldn't find any major differences in electronics or hardware, so I may just go for it.  It probably won't matter to me anyway.
It will be kinda neat to have a shortscale again, and my first Gibson. Now, to sneak this under the Christmas tree and put a fake label on it:
To: Steve  From: Santa...or Aunt (MakeUpaName)
AFAIK there's no difference other than what you mentioned. I've played both, there's no tonal difference.
VeloDog
Actually there are 5 differences, none of which materially affect the tone.  The pickups, pots, bridge, tuners, neck, and body are the same.  Here are the differences:
-  STD has a Corian nut, Special has a plastic nut.
-  STD has trapezoidal inlays, Special has dots.
-  Std gets the flower pot/holly inlay on the headstock, it's omitted on the Special.
-  Std gets premium nitro finish, Special gets the thinner cheapo finish.
-  Typically (but not always) the STD has a 1 or 2 piece body, the Special may have as many as 4 pieces.
I have friends who work at the Nashville factory.  They all say the deluxe nitro finish process on all the higher end guitars is an incredibly labor-intensive and time-consuming process, and that's where most of the savings are on the Special/Faded models.
Quote from: VeloDog on December 14, 2014, 06:14:20 AM
There is some really valuable info for anyone seriously considering getting one of these.  Thanks.
We already mentioned the inlays and the finish. I disagree about the body pieces and the nut. The SG Special I played recently was definitely a very nice two-piece body and the nut was definitely corian, not plastic (not that there would be more than a few cents difference in cost anyway).
The gloss nitro finish after buffing is likely just as thin as the cheaper matte finish. But you're right, it's much more labor intensive.
I actually prefer dots over trapezoid inlays on most basses for some reason.
FrankieTbird
I've never seen a plastic nut on any Gibson USA model, although they've made so many surprising changes lately that nothing could really be a surprise any more.  Still, the way I see it, no Gibson should ever have a plastic nut.
The multi-piece bodies are a fairly recent change for Gibsons also, I think.  I don't recall ever seeing more than three pieces until now.  I think in the "Special" or "Tribute" series guitars, it's hit or miss.  You may get a one-piece body, or you may get a four-piece body.  I have a 2011 SG Junior 6-string with a one-piece body, but mostly the ones I've seen have been two-piece.  I also bought a new Firebird Tribute a year or two ago online, and it showed up with a four-piece body.  I didn't like the guitar so I sent it back for a replacement.  Same model, same finish, same everything.  That one came in with a two-piece body.
None of my guitars have a G-Force, however.   ;)
ack1961
Quote from: westen44 on December 14, 2014, 01:02:35 PM
Same here. Unbound dot necks for me.
Quote from: FrankieTbird on December 14, 2014, 06:05:08 PM
I replaced a nut on a SB350 once, it was plastic, and appeared to be original. Can't say I'm 100% sure if it was ever replaced before,
but it was right size and shape. Found it in the parts drawer yesterday, it's plastic right - and appears to have had laquer on the sides,
altough I would not call this hard evidence.
Maybe other SB owners can verify this lo-grade-nut story?
VeloDog
#13
I certainly do not wish to be argumentative as I hate that kind of thing.  I will just explain how I came to be fairly certain that plastic nuts and multiple piece bodies have been used on many Gibson guitars for a long time now.
At the bottom of this post is the last spec sheet I had for the Faded series.  Note that it lists a plastic nut.  My spec sheet for the Special series doesn't denote the nut material at all.  When the Special came out it was largely just a renamed Faded model with a few different finish color options.  I assumed that the plastic nut carried over to the Special, but it may be that Gibson found it simpler to stay with one nut for all their models, I dunno.  The guys I know at the factory say small changes like this drive them crazy and that it would not be out of character at all for Gibson to have continued using plastic nuts on the early Specials until they ran out of them before switching to Corian.  I don't know for a fact that happened but I'm just saying nobody should be surprised if it did.  I can ask if it proves to be a burning question.
There is no question in my mind that plastic nuts were used on many of the cheaper Gibson models.  I know for a fact my 2008 Faded SG bass had a plastic nut that I replaced with a bone nut.
Additionally, the 2007 STD SG bass that I later bought has a 2-piece body (and Corian nut).  Multiple pieces have been used for over 20 years now.  One of the engineers I know that used to work at Gibson told me that finding large slabs of Mahogany was getting harder and harder as fewer old-growth Mahogany trees were available.  He also said large scrap pieces that used to be discarded were now being used for the cheaper model bodies.
As to Dave's comment about the number of pieces, I wasn't saying that the Special necessarily had to have 4-piece bodies, only that they might contain up to four pieces.  Not necessarily unusual to find 2-piece bodies but also not unusual to find 4-piece bodies on the cheaper models.  Or 3-piece bodies for that matter.  I suspect (without knowing for sure) that's one of the reasons that the burst version of the Special came out; the burst would better hide the number of pieces in the body.
The above is what I think I know.  I'm happy to be corrected if I have erred in any detail.
The info below came directly from Gibson's web site from about 4 years ago
FEATURES FOR GIBSON SG BASS GUITARS - Faded Models
    Pickups: Neck: Vintage-style TB Plus bass humbucker
    Bridge: Bass Mini-humbucker
    Hardware: Chrome
    Fingerboard: Rosewood
    Scale: 30-1/2"
    Nut Width: 1-1/2"
    Nut: Molded plastic
    Bridge: 3-way adjustable
    Neck Material: Mahogany, rounded
    Body Material: Mahogany
    Controls: 2 volume,1 tone
    Includes Gibson gig bag
The Gibson site now has the SG faded as having a corian nut.  MusiciansFriend says it is molded plastic.
Gibson site---
Neck
Species   Mahogany
Nut   Corian
Nut Width   1.600" +/- .050"
Headstock Silkscreen   Gibson Logo
Truss Rod   Gibson Adjustable Truss Rod
Truss Rod Cover   Bell-shaped cover, stamped "SG"
MusiciansFriend---
FEATURES
Hardware: Chrome
Scale: 30-1/2"
Nut Width: 1-1/2"
Nut: Molded plastic
