Author Topic: Lowe Shop Notes  (Read 114771 times)
« Reply #90 on: November 25, 2015, 09:01:06 PM »
Back into the details...finishing up the wiring harnesses I started.
« Reply #91 on: November 29, 2015, 04:49:48 PM »
Working on necks...installing inserts, adding serial numbers and cleaning up the polishing compound after the headstock finish:
Rounding the fret edges and "rolling the fretboard" slightly:
Something's missing, though:
« Reply #92 on: November 29, 2015, 05:07:10 PM »
Buttoning down the details...in addition to the swimming-pool rout, the area where the Switchcraft jack sits needs to be enlarged, and a small channel channel is sanded with a Dremel to accommodate the CTS pots and wiring, and pickguard screw holes are chamfered to prevent paint chipping:
All screw are stainless and the holes have a little beeswax added to make maintenance easier over time:
Models with pickguard-mounted pickups get connected to the ground:
The P'Nobird has its pickup mounted to the body, so it's connected at the same time as the bridge ground:
I think I'm gonna' need a bigger wall:
« Reply #93 on: December 08, 2015, 10:47:33 PM »
Lots to update this week.
I received a shipment of new Hipshot licensed machines...and they're now 100% shiny chrome:
I routed out and prepped the last two LSP bodies:
Enlarging the rout for a Switchcraft jack:
« Reply #94 on: December 09, 2015, 04:48:28 PM »
Brad, what's the nut width on the 32" conversion necks?  I need it with a tilt paddle headstock, maple/rosewood.  Thanks.
« Reply #95 on: December 09, 2015, 08:04:18 PM »
Carlo,
Here's a link to the current order form:
http://www.lowecustomguitars.com/wp-content/uploads/2015/07/LCG-Order-Form-MEDIUM-BASS-NECK.pdf
If you want holes drilled, it can be done, but the OEM needs very specific dimensions.
That can be written in the notes section.
Brad.
« Last Edit: December 09, 2015, 08:48:06 PM by BeeTL »
« Reply #96 on: December 10, 2015, 02:08:35 AM »
Thanks, Brad!
« Reply #97 on: December 10, 2015, 07:22:18 PM »
No problem, and thank you!
« Reply #98 on: December 11, 2015, 05:11:14 AM »
What's delivery time?
« Reply #99 on: December 11, 2015, 04:31:21 PM »
I'm saying 8 to 12 weeks.
The OEM has been pretty busy with NAMM work, but that may be quieting down.
I had both an 8-week and 10-week neck ship this week.
8)
Back to the builds:
Next, I Dremel a groove for the wiring harness to clear the large CTS pots, and then drill the string-through holes:
Here's how I ensure the ferrules holes drilled from the back line up with the string-through holes drilled from the front:
Ferrules hole drilled SLOWLY, then they are installed:
Necks getting strings and guides:
And a gallery shot:
« Reply #100 on: December 13, 2015, 08:14:12 PM »
CUSTOM USA Ridler BASS #1
« Reply #101 on: December 13, 2015, 08:25:04 PM »
CUSTOM USA Ridler BASS #2
« Reply #102 on: December 13, 2015, 08:30:44 PM »
CHIMERA Series LSP #3 - Sonic Blue
« Last Edit: December 13, 2015, 08:37:31 PM by BeeTL »
« Reply #103 on: December 13, 2015, 08:38:04 PM »
CHIMERA Series LSP Bass #4 - Seafoam Green
« Reply #104 on: December 13, 2015, 08:43:36 PM »
CHIMERA Series LSP Bass #5 - Antique White
