NBD: Epi Goth T-bird
Started by georgestrings, March 24, 2014, 10:04:18 AM
pilgrim9
I did a candy apple red one like Marks but routed the body instead of the neck heel. It needs to go about a 1/4" deeper and 1/8" wider on each side. If you stay with the original 3 point it needs a thin shim under the neck to get the neck angle right, the original necks heel is tapered but the pocket is flat. When I routed the body I covered the edges of the neck pocket with blue painters tape and went real slow with the router and got a real clean edge with no chipping.
If you push something hard enough it must fall over.
georgestrings
Thanks for the additional info, everyone - it's been very helpful...
    - georgestrings
georgestrings
Quote from: pilgrim9 on March 26, 2014, 07:33:19 PM
This has been especially helpful, as that's the exact approach I'm considering...
Which end of the neck pocket did the shim have to go??? It would be nice if I could figure a way to route it so that I don't need a shim, to be honest... I'm sure I'll have a better idea once I remove the neck - although I don't have alot of wood working experience, I'm a very experienced mechanic - and have successfully built a few nice Fender basses and guitars, besides doing all my own setups for quite a few years now..
     - georgestrings
While I did a lot of work on mine, it did go to Mike Lull for a set up, when I picked it up he did mention that he shimmed the pocket. It's my only project bass and as that it's fun, a semi polished turd that sounds very 7enderish to me - which means if I want that tone I don't have toplay or own a 7ender.
It'll be a fun project George!
Quote from: CAR-54 on March 25, 2014, 06:04:29 PM
Denis (with Carlo's input) converted one of those with good results, or am I mixing up something...?
Mine was a '76 Gibson Thunderbird which was converted to a Fenderbird in New York City sometime in the 1970s. I bought it without a neck on it and it now has a '76 P-bass neck on it. The Fender neck originally on it had a slightly different heel than the '76 neck so Carlo had to fill out the neck pocket a little.
Quote from: lowend1 on March 25, 2014, 02:31:11 PM
Gots da big neck, like my white CS/LE.
Me loves dat neck.
It appears the newest bolt-on Epis finally went to a 1.5" nut width.
Black plastik is fantastik
georgestrings
Quote from: exiledarchangel on March 29, 2014, 10:43:03 AM
Me loves dat neck.
Yeah, it's way nicer than I would've guessed - feels just like my Highway One P neck, just painted...
    - georgestrings
