CURRENT CATALDO
Quote from: dadagoboi on September 02, 2014, 10:12:06 AM
Thanks, Bill!
Here's the three hour total time refin I did yesterday to a metallic silver Squier body for a long time customer.  Scuff sanded with 320/400, shot with arctic white ACRYLIC lacquer, 3 coats in 15 minutes.  Waited 30 minutes and shot with 3 coats of clear.  It was completely dry by this AM. No buffing or polishing necessary.  It will go out Monday.  That's the advantage of using modern automotive products.  Proper prep and good gun technique and it's done.
I'm pretty sure it was done the same way in the Indonesian Squier factory. The silver was high gloss but very thin over polyester primer. No buffing makes for a less labor intensive finish.
So, I  could use the clear acrylic lacquer over my stained bodies and have less sanding/buffing?  Does it also fill grain better?
Quote from: drbassman on September 06, 2014, 10:00:12 AM
You could probably use it over stained bodies but it has very little filling properties.  On solid color finishes it works very well over polyester primer surfacer which is auto industry stuff, basically spray on bondo.
On stained or natural wood I use 2 coats of industrial (lacquer) sanding sealer sanded between coats and 3 coats of acrylic or nitro lacquer.
You might consider doing your experimenting on scrap wood instead of competed bodies, it might save a lot of time in the long run.
Sanding technique has a huge effect on the final result of any finish job IMO.
Could you give me brand names on the sealer and acrylic?
Carlo your stuff just keeps looking better and better!
Bill. be sure it shows trees too  :)
Rob Francis
Thanks, Rob!
Bill, I use Mohawk heavy bodied sanding sealer, M610-1657 and Mohawk Piano Lacquer clear, M610-1307.  The sealer gets thinned 50/50 and the piano lacquer is ready to shoot.  I also use their Ultra Penetrating Stain and a lot of other products.  I'm pretty sure Scott knows the Rochester Mohawk distributor.
For solid colors I'm switching to acrylic automotive lacquers and compatible products from TCP Global.
Quote from: dadagoboi on September 06, 2014, 11:55:12 AM
Thanks, Rob!
Thanks Carlo, I've been to the Mohawk dealer after our last finishing chat.  Do I still need to grain fill with the Mohawk sealer?
Quote from: drbassman on September 06, 2014, 03:03:40 PM
I have never used grain filler. YMMV.
Quote from: dadagoboi on September 07, 2014, 02:58:05 AM
Cool!  That's music to my ears!
#233
The RR.  It's a combo of 51P (slab body but with belly and forearm cut and heel contour, pickguard), 60 Jazz (modded Jazz body outline, stacked pots) and TBird guts.
1.75 " thick one piece basswood body. 8.5 lbs, ThunderBucker '63 in the neck, hot single coil close to the bridge for extra sizzle.  Monza Red lacquer.
Naked
The pickguards fit under the the pup ring to allow the customer to switch them out and still keep the clean no screws look.
Modded pup ring spacer for pickguard attachment.  You can see the holes in the guard at the left
very tasty! whats the single coil pickup in there?
Quote from: Highlander on November 09, 2014, 03:27:54 PM
Gorgeous...
Quote from: clankenstein on November 09, 2014, 04:32:19 PM
Thanks!  Duncan SCPB-3 quarter-pounder rewound by ThunderBucker (Steve Soar).
Very nifty!  I like it!  Another beautiful creation.
 A J bass even I could love.
