Author Topic: CURRENT CATALDO  (Read 137870 times)
Re: CURRENT CATALDO
« Reply #795 on: December 21, 2019, 06:11:07 PM »
Wow Carlo I thought Kinko's had a special place in your heart.
Re: CURRENT CATALDO
« Reply #796 on: May 06, 2020, 12:28:03 PM »
What I did on my Covid Vacation.
Re: CURRENT CATALDO
« Reply #797 on: May 06, 2020, 01:16:09 PM »
 8)
shadowcastaz
Re: CURRENT CATALDO
« Reply #798 on: May 06, 2020, 05:19:35 PM »
Re: CURRENT CATALDO
« Reply #799 on: May 06, 2020, 06:19:38 PM »
That is why they call you lightnin'.
That is freaking awesome!
Re: CURRENT CATALDO
« Reply #800 on: May 07, 2020, 06:19:08 AM »
That is GORGEOUS.
Stacked vol/tone behind the bridge? That's a cool look...
I know we've seen that bridge before, but I forget, what is it?
Something about the cut-out decoration makes me wonder is it semi-hollow or chambered?
Or the middle slab is solid all the way?
Re: CURRENT CATALDO
« Reply #801 on: May 07, 2020, 07:57:14 AM »
 :toast:
Re: CURRENT CATALDO
« Reply #802 on: May 07, 2020, 10:02:43 AM »
:toast:
Pretdamn near full hollow.  There's a block for the pup to screw into and one for the bridge/tail. The sides are about 3/8" thick when the perimeter is routed to final size.
This was mainly going to be a 'proof of concept'.  The sides were built  from pieces.  All my other basses use a standard 14 x 20 blank.  I'll draw the perimeter on it and remove everything that's not necessary.  This frame took a 4' x 8" wide board and 2-3 hrs to build,probably more. Entire bass weighs
Bridge and neck are modded from an 8 string Rogue.  Cataldo tailpiece. I forgot the block under the tailpiece so I through glued front to back 1/2" dowels for each screw.  Worked out, no tailpiece tilt.
Bass weighs 7.8 lbs.  Top and bottom are from Lowes, I went through a stack of about 25 2'x 4' pieces ($17, void free, thus the faux binding).
Here's some more pix of the build.
Cheap quick connects, pot fits thru the larger triangle. Endpin jack, seems appropriate. Bridge is adjusted for height with shims under it or the neck, none were needed.
I can probably reduce the weight by a quarter pound. Trans white toner top, trans black sides and neck, natural "binding". Three separate tapings.
FrankieTbird
Re: CURRENT CATALDO
« Reply #803 on: May 07, 2020, 02:13:40 PM »
Looks great!  Curious why you didn't change the neck pitch instead of sinking the bridge?  Is there a benefit?
Re: CURRENT CATALDO
« Reply #804 on: May 07, 2020, 04:18:37 PM »
Thanks. Bridge is made to be inset, it's about 3/4" tall. Since it matches the neck I knew that if I made the neck pocket the same depth as it was on the donor bass and made the bridge route the same relative depth as the donor body I should be OK. I strung up and played the bass before disassembling for finishing, including testing the wiring.  Standard for any prototype...that's how I discovered I needed to do something about the lack of a block under the tailpiece.
Unrepaired divot from router miscue is visible. Original Rogue headstock, meh.
Re: CURRENT CATALDO
« Reply #805 on: May 08, 2020, 03:36:42 AM »
Cool concept!
I’d put new tuners on though. The rusty ones don’t do it justice.
clankenstein
  • Never Gutless!
Re: CURRENT CATALDO
« Reply #806 on: May 08, 2020, 04:05:32 AM »
Sweet! Does it make much sound acousticaly?
Louder bass!.
Re: CURRENT CATALDO
« Reply #807 on: May 08, 2020, 11:29:42 AM »
Cool concept!
I wouldn't put those tuners on a customer's bass but this one isn't for sale.  It originally just a chance to try out some ideas:hollow body, cheap plywood, and finish techniques.
Thanks! I strung it up an played it for a while, then cut  the holes.  It was immediately louder.  A fresh set of strings and some scientific tuning of the holes might make it louder but it's audible enough unplugged so an amp isn't necessary for practicing. I'll do an unplugged clip if I ever get around to recording it.
Re: CURRENT CATALDO
« Reply #808 on: May 09, 2020, 04:33:37 AM »
 :popcorn: :mrgreen:
Re: CURRENT CATALDO
« Reply #809 on: May 09, 2020, 12:15:43 PM »
Very cool!
