Author Topic: Planning the new bass  (Read 20220 times)
Re: Planning the new bass
« Reply #90 on: May 11, 2013, 02:54:27 AM »
you the Doc....
If it doesn't, I have a backup plan.
« Reply #91 on: May 11, 2013, 10:29:35 AM »
TV Jones Thundertron pole screw spacing (.pdf)
1.90 in. total center-to-center for the neck pickup, 2.03 in. for the bridge pickup. By comparison, a SCPB pickup is 2.10 in. If you use a Fender-spaced bridge and place the bridge pickup too close to the bridge, you might run into an alignment problem. All depends on where you place the pickups.
« Reply #92 on: May 11, 2013, 07:39:22 PM »
Thanks Dave, I saw the PDF.
ramone57
« Reply #93 on: May 13, 2013, 09:57:04 AM »
I'd think the f-hole would look better with the fat end at the bottom.
« Reply #94 on: May 13, 2013, 10:02:34 AM »
I do too.   ;D
« Reply #95 on: May 13, 2013, 10:27:07 AM »
I'm starting to think that an unconventional S-shaped sound hole would be interesting.
ramone57
« Reply #96 on: May 13, 2013, 12:41:59 PM »
I agree.  something like an infinity sign  ~
« Reply #97 on: May 13, 2013, 01:32:49 PM »
I'm ahead of you guys already.  I sketched something out that follows the contour of the top edge.  Here's a quick view.  Also cut the first body out.  1.5" sapele, hard beautiful stuff!  Will glue up some board later this week for maple and mahogany versions.
Also made the template for the cavity routs.  Slow but steady...........
« Reply #98 on: May 13, 2013, 06:35:17 PM »
That's a little straight-sided.  Needs to be more curvy and "voluptuous"....
« Reply #99 on: May 14, 2013, 04:03:34 AM »
Yeah, my drawing skills suck.  I'm going to keep working on it.  Gonna keep refining the pick guard too.
« Reply #100 on: May 14, 2013, 05:38:51 AM »
« Reply #101 on: May 14, 2013, 06:53:30 AM »
OK, I like the pickguard, but I'm still not sure about the f hole.
I was thinking yesterday that maybe my semi-holllow desgin WITHOUT and f hole would be nice.  Kinda Hofner-esque.  I'm still working on this angle as well.
« Reply #102 on: May 14, 2013, 09:55:02 AM »
« Reply #103 on: May 14, 2013, 10:00:22 AM »
^ That design is from a faux f-hole sticker I found online, http://www.inlaystickers.com/servlet/the-119/F-Hole(Combo-style)-Sticker/Detail
You can use the sticker and have the f-hole look but with less feedback.
My '64 Gretsch 6070 has painted f-holes. Nobody ever notices until I tell them.
« Reply #104 on: May 14, 2013, 11:29:45 AM »
I'm starting to lean toward no f hole unless I see one that knocks me out.
