That bad huh?
OK, you did ask:
1. The whole thing falls off if you remove all the strings.
2. I have had the threaded inserts pull out of the body on me when string tension is applied.
3. It's on stilts and it gives me the same confidence that a house on stilts would.
4. You can only adjust the height of the bridge in three places, there is no (easy) means to individually set string heights.
5. When installed (top loaded), the ball end of the string is so close to the saddles that the silk (or ratty end bit of unsilked strings) can go over the saddle, particularly on the E string. I don't claim to know what that might do to the sound, but it looks bad, and I wouldn't tolerate silks over the nut so why should I tolerate it at the bridge saddle?
That's the main points for me.
Now, I'm going to disappear back behind that can
