Author Topic: Hipshot RIC bridge  (Read 3208 times)
Hipshot RIC bridge
« on: March 27, 2012, 04:46:41 AM »
Anyone try, or even see, one of the Hipshot replacement bridges for a 4003?  I'm curious about them.  I have one of their replacement bridges on a TB and it is excellent.
Re: Hipshot RIC bridge
« Reply #1 on: March 27, 2012, 06:28:26 AM »
A friend of mine had one on a 70's Ric and it rattled.
But I also read some good reviews, and it does enable palm-mute, and it's a drop-in, and it follows the aesthetics of the rest of the bass, so I guess it's worth a try if you dislike the Ric unit.
« Reply #2 on: March 27, 2012, 08:02:06 AM »
I've been back and forth with those. First, I had an original brass one. Worked great, no issues. But it weighed a ton and seemed to darken the tone too much. Then, I bought a newer aluminum one. Better weight, better tone, but the G saddle wobbled like crazy, and the D a little bit too. I tried notching the groove that the height adjustment screw rests in a little deeper, but that didn't quite do it. I finally ended up putting the stock bridge/tailpiece back on, but with the mute completely removed (no more thumb screws), and I replaced the piece of junk philips head intonation screws with some socket cap head screws so I can actually adjust the bridge. What I'd really like is a chrome plated metal plate in the shape of the stock unit with a good old Schaller roller bridge on top.
« Reply #3 on: March 27, 2012, 08:54:52 AM »
How about nickel silver for the plate?  What thickness to make the Schaller the proper height?
« Reply #4 on: March 28, 2012, 05:10:40 AM »
Are you suggesting you could fabricate one with a Schaller bridge on it and nickel pated? That would be interesting.
« Reply #5 on: March 28, 2012, 05:33:53 AM »
Should be pretty easy.  The base would be solid nickel silver, same as ThunderBucker covers and rings.  It's available in varying thicknesses.
« Reply #6 on: March 28, 2012, 08:29:01 AM »
1/8'' should do it. Not sure why you would do nickel plating though, since all the Ric hardware is chrome. I guess the pre-mid 80s tuners were nickel, but the tailpieces and pickup surrounds and covers are chrome. I know the Schaller is not everyone's cup of tea, but I've had them on probably a dozen different basses over the years and have zero complaints. I actually quite like them. No sharp edges like a Badass, and no need to slot the saddles. I just put a little thread lock on there so the rollers don't move around every time I change strings.
Edit: OK, I think what you're saying is, solid nickel silver - no plating required? Good idea!
« Reply #7 on: March 28, 2012, 08:48:28 AM »
The nickel isn't plating.  The material is an alloy of nickel so it polishes to a mirror finish  It's sort of like solid stainless compared to chrome plated steel.  Nickel silver is easily chromed, it just adds to the cost significantly if you're doing small numbers.  A prototype could be done in aluminum.
Spiritbass
« Reply #8 on: March 28, 2012, 09:12:28 AM »
I put a brass Hipshot on my (2010) 4003 last year. No rattles. My only nit-pick is that the area in front of the saddles could have been smoothed more before plating. There are machine marks still visible. It's cosmetic, doesn't affect function...
