Author Topic: Class D Amps - article  (Read 3678 times)
« on: March 08, 2012, 02:13:04 PM »
I may be late to the party compared to some of you, but I found this article outlining the increasing popularity of class D amps both interesting and non-technical.
http://spectrum.ieee.org/geek-life/tools-toys/classd-audio-the-power-and-the-glory/1
I just know that I'm very grateful for my Genz-Benz Shuttle 6.0 which is incredibly light (3.75 pounds) and performs so astoundingly well.  It's a great tool.
Enjoy.
« Last Edit: March 08, 2012, 02:43:16 PM by Pilgrim »
Re: Class D Amps - article
« Reply #1 on: March 09, 2012, 06:12:05 AM »
The reduction of the weight is a huge advantage.
But so far all the Class D amps that I've tried had a terrible lack of dynamics.
It makes no difference if you caress the strings with the flesh of your thumb or if you hit them hard with a pick; it all comes out the same.
As long as they don't find a solution for that problem I won't be buying a class D amp in a hurry...
« Reply #2 on: March 10, 2012, 05:49:26 AM »
A lot of lightweight class D bass amps are pretty anemic. The Genz Benz stuff definately is not. I just bought some new Class D PA gear, including a set of active 1000watt JBL PRX15M cabs. They are very nice ;D. Not all Class D amps are created equal.
« Reply #3 on: March 10, 2012, 06:09:54 AM »
back in the day if you had a couple voice of the theater cabs and a pile of crown power amps you were good to go. sometimes smaller (new stuff ) is much better.
« Reply #4 on: March 10, 2012, 06:29:01 AM »
That's what I used many moons ago and it was a great sound ;D. These JBL PRXs are 44.5 lbs and 1000watts each, freakin' crystal clear at high or low volume , plenty good bottom, and just plain sound great. Still a little tough to grasp that so much juice comes out of such  a small package. I do not miss miss the HEAVY artillery.
Aussie Mark
« Reply #5 on: March 11, 2012, 03:11:04 PM »
You should try a Markbass TTE-500 (4 tubes, 500 watts, 3kg) or a Genz Benz Streamliner (3 tubes, 900 watts, 2kg).  Both these Class D amps have a lot of dynamics IMO.
Cheers
Mark
« Reply #6 on: March 13, 2012, 12:43:33 AM »
This is the often overlooked (or hidden) fact that budget amp makers of Class D designs don't want well known: even with the reduction in weight and power consumption, unless an amp has SUPER tight supply and output stage regulation, it's going to become a doorstop with very little use. Even the best switching designs are going to be, at best, half as long-lived as a conventional topology amplifier. The cheapies? There are lots of threads in online forums documenting many a budget lightweight amp's demise after just a few months.
« Reply #7 on: March 13, 2012, 08:56:19 AM »
I know Rob's love for tube amps and in fact I share it!
But:
A lot of times I took my Hiwatt with me onstage. In the end it had to be turned down otherwise it was too loud for the small venues we play in. So I played a very big and heavy tube amp on a very low volume... Of course I could go for a 50 or 100 Watt tube amp, but I decided to have a smaller amp for smaller gigs. I know It doesn't sound that good, but good enough and I let the sound engineer do his job by creating a good PA sound.
« Reply #8 on: March 13, 2012, 12:55:49 PM »
The sound is not the problem, Chris. For example: The Orange Terror Bass emulates the tubeamp AD200 perfectly soundwise.
The lack of dynamics is the problem.
I know they're not all equally as bad: The Ampeg PF500 that I tested was much better.
« Reply #9 on: March 13, 2012, 02:03:54 PM »
ampeg has had some problems with the pf500 cutting out,  myself included so it got returned.
« Reply #10 on: March 13, 2012, 02:11:10 PM »
Rock and Roll was never supposed to be easy.
« Reply #11 on: March 13, 2012, 02:24:42 PM »
Class D is probably like every other class of equipment - not all are created equal.  Like Rahock, I'm OK with the dynamics on my G-B Shuttle.
