Gibson RD Artist Switching??
Started by FlatEric, February 13, 2012, 12:09:42 PM
FlatEric
I'm almost certain that someone will be able to help with this. ;D
When I first had my RD, the switches need a quick squirt - nothing major,
just to sweeten things up.
I found there was a "Sweet" spot  on the mode switch, that made the
whole thing a lot more interesting.
The back position, I don't bother with, to be honest - compressed lower powered
on the neck and tinny on the bridge - both together, alright but I dont use that.
Mid position, fine - treble boost fine but there is an "inbetween", just before the
switch goes all the way.
So good, that for a day or two I set the switching to that selection, using a piece
of card, so no harm was done.
As I have been thinking about selling it, I have been using it again and over the weekend
couldn't resist trying it again.
I have played another Artist and a couple of Std's but never another Artist against mine.
So. . . . on the MODE switch, could someone point out which contacts should make/break
in the 3 positions - just so I can check.
I have to admit that engaging the "Supercharger" mode makes me think I should hang onto it.
Don't get me wrong, I have always been more than happy with the way it is/came to me and
always cuts through very well when gigging but I would like to see how yours is wired - Jules.
Uwe and anyone else.  :)
Stands back and waits for deluge of replies/pics/sketches of what makes/breaks!!
Don't confuse me with a wiring diagram!!!!! ;D
Cheers, :)
Now a little more wiser. . . . .
neepheid
I don't think I can help you, as I suspect you're talking about the three way Moog switch.  I have a late 1979 RD Artist with the separate mini toggles for comp/exp and bright.  Sorry!
warriorbass05
mine is stock...I am not quite clear on the question...
Endorsing Artist: Spector Basses   www.spectorbass.com
Bluesman Vintage Basses
www.bluesmanvintage.com
FlatEric
Quote from: warriorbass05 on February 13, 2012, 05:21:47 PM
Excellent.
I will get a couple of shots to show you what I mean.
Will come back to you later.
Cheers. :)
FlatEric
#4
Mode Switch
CENTRE
BACK - COMP/EXP
FORWARD - BRIGHT
JUST BEFORE IT MAKES CONTACT ON "FORWARD" THERE IS A POINT WHERE
BOTH CONTACTS ARE OPEN - THIS IS OVERDRIVE!!
Hi.
These are the best shots I can get, at the mo'. :)
X = Contact      O = Open (no contact)
Can you have a look at yours and see if yours is as mine.
Look forward to your reply.
Cheers. :)
Edit:
Got this off Jules' site and it seems to show (to an electrical Muppet) that 8 moves
away from 7 and when the switch is pushed over, makes contact with 9, like mine does,
if I have read it correctly!
The "Supercharged" section is when 8 moves away from 7 and doesn't make contact with
9 - in other words "8" is on it's own.
Rehearsal tonight - Going for Supercharged - will report back.
Cheers. :)
I "FIXED" mine years back - they are still sitting on the shelf in the shed... ;D
warriorbass05
I will have to take mine apart to see if it is the same
FlatEric
Ok, here we go!
Played my RD last night, for about 2 1/2 hrs, with the switch set to my
new "Hot" setting, by putting a simple cardboard spacer inbetween, so
contact can't be made with the far right contact and enjoyed a great night.
I have no idea what part of the circuit is doing what but it is a very interesting
addition to an already interesting bass.
No pops, crackles, no smell of burning ( ;D) and using that battery that has been
in there for well over a year.
Anyone who has got an RD, fancy a go??
Any boffins who can explain what I have found?
Any input, would be great to hear from you.
Cheers. :)
