What is the purpose of the 220k resistor and the .02mfd cap that I read as being between the mudbucker and the switch. Is the 220k in there to keep the mudbucker and the lead pup from squelching each other in full volume? What is the 02mfd cap for?
That resistor works along with the cap and inductor in the orig circuit to create various filter configs (
RLC filters) depending on the position of the varitone switch. I
think the filters end up working like this in the 60s EB-3:
Pos 1: Mudbucker only with a wide band-rejection filter, letting mostly just the low frequencies thru
Pos 2: Bridge pickup wide open
Pos 3: Mudbucker and bridge, with high-pass filter applied to the mud ("choking" the lows out)
Pos 4: Same as 3, minus the bridge pickup
Anyway, you won't need that 220k resistor if your're ditching the inductor and cap in your new circuit.
If you haven't already bought the Black Ice, you might try picking up some small signal diodes like you mentioned (BAT41s, etc...) and wire a pair of them in parallel - each with opposite polarity - in place of the black ice in your diagram (similar effect for ~$0.40). Another idea might be to try them in place of the tone control cap for control over the amount of clipping... or even wire one master tone and one clipping pot on the output, instead of a tone control for each pickup.
I still need to wrap my head around your new wiring diagram. I wasn't understanding the connections on the 3p4t at first glance. I always have a hard time reading wiring diags, though.
Cool ideas. I like the sleeper approach.
