EB-3 wiring
Started by drbassman, November 08, 2011, 08:50:03 AM
I had done series parellel with a p-bass pup years ago, and I always liked the variety. On the Fender it just gave it an opened up honked out sound, but lower output.  So I cool with that mod, and curious on how it will sound on a mudbucker. I think it may sound better on the lead pup, as it is thinner. I am loading a Duncan SM2b in mine, but haven't wired it up yet. Just a guesstimation that it would blend more effectively.
That's what I did with the MB in the PC...
OK, here's the deal.  I have the hum bucker Sniper gave me that Curtis rewired and wound to original specs with the standard braided 2 conductor wire on it.  I think I'd like to use that since the current pup (and the bridge pup) from the EB-3 isn't giving me any readings no matter how I combine the wires with my meter.  I'm gonna call Curtis and see if he can rehab them for me.
In the meantime, I want this bass together and playable.  So, here's what I want to do since it will be months before the pups can be rehabbed.  I want to use the 2-wire mud bucker that I have and a reissue bridge pup (temporarily) with a 4-way switch and 2 vols - 2 tones.  How might that schematic look?
#18
Exactly like like the wiring diagram below:
http://bassoutpost.com/index.php?topic=1295.0
It is in the second post, by ramone57.  That is the stock wiring for an eb-3, so where you have the choke in that diagram - and you want to skip that - either leave it blank (a jumper wire) or stick something else in there.  What?  It could be just another cap of another value to alter the sound, or some do-dad, or just nothing.  It would function like a regular toggle but with a 4th position.
Thanks, that's one even I can follow!!!
OK, what the heck is the difference between 400 and 600v caps?  Geez, this is a snake pit!  What should I buy?
All you folks that fiddle around with these silly tone things... it's all in the fingertips and position along the strings... :P ;D
QuoteOK, what the heck is the difference between 400 and 600v caps?
For inside an old EB-3, nothing.  Those voltage ratings are for what the cap will handle, but in a bass something would be both wrong and deadly if you were to put voltage through it.  Technically we do, just its teensy miili-voltage that the pup generates.  Get the cheapest.
Years ago I pulled a cap out of a Gibson bass and took it into a guitar shop to get another.  I loved the tone control and figured if they could get me one, I could put it into something else.  They were confused why the bass had an amplifier part in it - it was 400v rating.  Fender used low end disc caps, like you can get at radio shack, but the signal would filter the same and you would never need a high voltage cap.  So, that was probably what Gibson was using - amp parts/bulk buying.
Quote from: eb2 on November 10, 2011, 03:27:20 PM
i have been told this same thing by several electronic engineers concerning the chokes in the EB series ... amp parts in a guitar. max we are talking about would be about 500 milli volts output in a mudbass.
Interesting.  So many builders swear by Orange drops over the low end caps.  They claim they sound better that the other caps, but who knows?
Quote from: drbassman on November 11, 2011, 05:50:22 AM
Interesting.  Some many builders swear by Orange drops over the low end caps.  They claim they sound better that the other caps, but who knows?
That's an example of where psycho-acoustics (the ability to hear what you want or expect to hear) impinges on actual acoustics.  When it comes to discussions of parts like Cap type A vs. Cap type B, there are people who will go to the mat for their preference.  When it comes to this kind of tiny part, I find it difficult to separate the parts which actually make a difference from those which only make a difference on the psycho-acoustic level, in which you hear what you want to hear.
i rewired an old kramer with cts 250 pots, .47 orange drop cap and switchcraft jack. i noticed an immediate change for the better. could be the original electric were crap...
That is all top drawer stuff, so I would guess that was an upgrade.
Quote from: eb2 on November 10, 2011, 06:57:14 AM
OK, if I substitute a jumper for the choke, I just run a wire from the rotary switch lug #8 to the pot ground, right?  And how the heck do I figure out the numbers on the lugs on the 4-way?
