Dyed maple?
Started by slinkp, November 04, 2011, 10:01:11 AM
I like bright-sounding fretboards like Ebony and Maple.  I don't much care for the look of maple boards, though.
Now, I'm not fully up on the story with availability / ethics of using ebony, and don't really want to start a thread about that; but I had a random idea that I wanted to explore:  Is it possible to dye maple to look like a really dark wood?
... without it looking like crap? :)
Sure. Violin (/cello /upright bass) makers have done it for ages with low-end instruments, for the fingerboard they use "ebonized" maple.
Rickenbacker did enameled freboards on their 4003SPC models - Blackstar, Tuxedo and Redneck, matching the color of the body (black, white or red). Traditionally Rics have bubinga (african rosewood) fretboards, but rosewood is open-pore and for the enameled boards they needed close-pore wood, so they used maple.
Thanks Ilan for satisfying my curiosity.  Whether I will ever get to use this information is another matter... but hey, thinking about basses keeps me sane at work!
It can be hard to make it really black might look up ebonizing to get some ideas.
old banjos that were relatively inexpensive often used dyed pearwood for fingerboards and peghead overlays...
I would start here: http://www.homesteadfinishingproducts.com/htdocs/TransTint.htm
Transtint makes liquid dyes that you can mix with water or alcohol, the latter preferred in your application I would think, that can be applied as strongly as desired.  I've used their powdered dyes in the past with great results.
shadowcastaz
I have used both black & blue(blue not on fret board) to dye wood in the bat with good results.
I've used black and green and they are both really consistant.  I used them on curly maple which is sometimes easier to color as little variances don't matter as much.
This is worth a watch or two and James is a bassplayer.
http://www.finewoodworking.com/Materials/MaterialsArticle.aspx?id=30136
Transtint are metal acid dyes and should work well on maple.
IMHO nothing wrong with flat black paint either, depending on the look you're after.
shadowcastaz
[/quote]
I saw this vid a couple years back. Awesome results>
black leather dye (the alcohol based stuff) is relatively cheap and works well, especially with a lacquer topcoat.
