Just an idea...
Started by Kevin_bluebass, January 16, 2011, 08:34:04 PM
I like my Reverses the way they were done in the beginning; Honduras, big headstocks and nickel hardware...and Resolites.
Radical thought has its place... (sorry Uwe - don't panic - I grew up)
Kevin - I toyed with taking the head off my RD and fitting Steinberger hardware back in the late eighties - you could use on of their bridges if you partially sacrificed the bodys shape for the bridge/tuner block - the string retainers would also be from the same components - job done...
Hohner used the same components on their "Jack" bass which comes up cheaply on occasion and they are official licensed parts...
Black plastik is fantastik
#18
"w/o losing the classic outline"
Doesn't work for me.  At  the least it looks like McGruff the Crimedog took a bite out of its ass.  With reason.
My '64 TBird II weighs 7.8 lbs with heavy vintage klusons and a big headstock.  TBird Reverse neck dive would be almost completely eliminated with a smaller headstock, minituners or ultralites and a THICKER BODY.  Weight would be less than 9lbs, possibly 8.5  Better solution IMO
Thicker/heavier bodies would be the solution for most neck divers, I agree. And I don't think the extra weight would be an issue.
