Jazz goes fretless - mini conversion project... (SHED content)
Started by Highlander, November 20, 2010, 12:48:59 PM
I may have slipped over to the Dark-Side with this one... :vader: [edited to drop the pics in]
Anyway, a Mightie-Mite ebonol and maple neck turned up earlier in the week, followed by some Roto flatties (45-105) and some black tuners... The neck has an almost mirror fin at the moment... I also dug out a pair of Fender US pups Scott sent over a few months back to fit to this beastie...
The neck needed some side shims so I used some veneer to pack out the sides - something to note re shims - she had a piece of "scratch" used to shim up slightly...
As I stripped the beastie down and I noticed the bridge on the Goat-Slayer being black and having the same screw positions... so...
As I was working (this is what Carlo termed as "going commando" ;D) I thought, "hmm... the front of the neck looks awfully natural wood..." and I spotted a can of black paint on the shelf...
Oh yeah, reference note... the Squier's standard pup values are about 6k - the ones that Scott replaced (with SD's in his) are about 7k and more trad Jazz (neck being slightly smaller) ...
Shed content...? welllll... there's presently 2/3rds of my herd holed up in there at the mo... plus a surplus neck...
  ;D
Looks like you have yourself set up pretty good out there!  The bass is looking good to !
... black machines fitted... not sure what to do with the face of the head - logo or just leave geared up for night-vision only - the string guide I borrowed off the old neck until I can get a black one...
... then I nearly had a tragedy of Grecian proportions...
... one of the original screws sheared off just into the body - a bit of gentle persuasion with a rubber mallet put Plato in his place...
... used a temporary screw to secure until I can lay my hands on a new set...
Here's another dilema - do I refit the white scratch and go "Tux" or leave her "Black-Beauty"...?
Anyway, all back together - a bit of set-up work and tested through the MAG... there is a slight hum but as I plan to dump the original pots that can be attended to when that is done...
Got a rehearsal tomorrow so that will be the iron test...
Hornisse
I'd need the Jizz in white... ;D
Forgot to add - she has a very dark tone...
(did I get away with that one...?)
You still need to buy a black control plate, some black knobs, a black pickguard, a black nut, some black screws, a black neckplate and a flashlight.
Black plastik is fantastik
Quote from: exiledarchangel on November 22, 2010, 01:23:30 AM
And tape-wrapped strings for another tasteful black element.  They also give you a nice sound with a bit more "upright" element.
I'm getting a black look from Jackie at the moment - she likes the silver and white...
I do intend to swop out the controls for old type black ones with probably a blend and a master volume, leaving the tone control in for balance (disconnected, of course... :vader:)
anyway... off to rehearsal... ;)
Quote from: Kenny's 51st State on November 22, 2010, 11:11:58 AM
Sorry Kenny, but as a president of the "never waste a hole" club, I can't let you do that. Seriously.
Put a 3-way switch on that tone pot hole, or even better, a rotary switch to choose neck, bridge, neck and bridge in parallel, neck and bridge in series, and something out of phase.
Quote from: exiledarchangel on November 23, 2010, 02:58:06 AM
Sorry Kenny, but as a president of the "never waste a hole" club, I can't let you do that. Seriously......
Ah, yes and that club would be headquatered in Greece ;D  Imagine that! ;)
Do you spend your off time waving red flags at bulls?  Just curious....  8)
