Author Topic: Daggum it. Stalled on a Bronco mod.  (Read 957 times)
« on: July 31, 2010, 06:47:54 PM »
I picked up a black Bronco not long ago.  Dropped a S-D Hot Rails pickup in it and the sound was OK, but since it's such a good base for mods I tried a '53 reissue SCPB pickup in it.
The SCPB actually fits pretty well as far as pickguard and the recess in the body - plenty of room under there, although I need to erlieve it just a bit on one side. A bit of Dremel work relieving the pickguard let me work it through. But that SCPB pickup seems pretty sensitive to string position, and the G and strings are located well inside the poles...the alignment is bad.  I figure that usually alignment with the poles isn't critical, but it seems to be a factor with this pickup, especially on the E.
So I had a bright idea....get a set of 4 threaded saddles, drill and tap the 2-saddle bridge to allow mounting 4 saddles, and use the threads on those saddles to manually position the G and E strings farther out and more in line with the pickup poles.
Got the saddles from Guitar Parts Resource and figured out placements (with the threads to align the strings as needed, it ain't rocket surgery) but ran into a snag....the screws for the saddles are an unusual thread that doesn't match any metric or SAE taps I have.  I spent a couple of hours running between hardware stores and couldn't match the threads.  Best I can figure they're a 6-40 screw, and although I found a few 4-40 screws and plenty of 6-32 screws, I couldn't find a hardware store with a 6-40 to test them against....much less a tap, although they're available for a couple of bucks online.  I'd feel better about ordering a tap if I could confirm what the threads actually are.
Hmmmm.
Maybe the best alternatives are either to get a Musicmaster bridge from Guitar Parts Resource ($20 + shipping), and see if the threaded saddles will mount on it - or to grab a file and just make notches in the stock Bronco saddles a bit farther out...improving the alignment of string and pole piece.  But there's not much room for another notch farther out on the saddle unless I make a notch just about over where the set screw is located.
« Last Edit: July 31, 2010, 07:02:52 PM by Pilgrim »
Re: Daggum it. Stalled on a Bronco mod.
« Reply #1 on: August 01, 2010, 01:58:15 AM »
Making your own customsaddles isn't an option? I mean, most of us have a friend that works with some dangerous metalworking equipment, willing to make some thingies for us for some beers etc etc :D
« Reply #2 on: August 01, 2010, 02:07:33 AM »
From an engineering standpoint it would be out-of-character for a manufacturer to use an exotic thread type... see if you can work out the tpi and dimension of the stock then check what it best matches to...
re cutting notches to suit - I strongly have the idea that you pride yourself on your workmanship - I played about with Badass 1 I had (1st to replace the three-point on the RD, then latterly on the Peter Cook - now it sits in the junk box), cutting new slots to make them line up better, which they did and it stayed on the PC until I came back to playing, but it just looked ugly, not the fact that it was, just all the cutting...
« Reply #3 on: August 01, 2010, 01:27:49 PM »
I put a SCPB pup on my EBO in the extreme bridge position. Had to angle it to get the string spacing exact.  You might consider that.  The string spacing on my buddy's Musicmaster is very narrow.  The Pup seems to be a Strat with the two outboard poles removed.
Here's a pic I found of a Bronco w/SCPB.  At least I think it is.
« Reply #4 on: August 01, 2010, 01:42:38 PM »
That pic on the bottom is a Bronco that belongs to Ponticat on the TB forum.  He has done a number of Bronco mods like that, and all involve angling the pickup.  I'm trying to get by without having to have a custom PG manufactured to hold the pickup, which seems like it would be necessary with that approach.  However, I really like the look of it!
Last night I ordered a pair of 250K CTS pots, switchcraft jack  and .47 cap to replace the existing electronics on the Bronco...from what I've heard that may make a difference too and the cost is minimal.
