Author Topic: Neck heavy?  (Read 2945 times)
Aussie Mark
Neck heavy?
« on: June 01, 2010, 04:26:41 PM »
I came across this on another forum.  Maybe we need a WTF section here.  Fancy adding 1.5lbs to your bass?
http://www.headsupstrap.com/
Cheers
Mark
Re: Neck heavy?
« Reply #1 on: June 01, 2010, 04:56:02 PM »
 I don't have too much trouble with my Reverses but it'd probably help my BaCH's out a bit........
Of course I could just man up too!   :gay:
we I need a Girlie icon smilie of some kind!  What about it Dave and Uwe?
« Last Edit: June 01, 2010, 05:19:47 PM by TBird1958 »
Re: Neck heavy?
« Reply #2 on: June 01, 2010, 05:17:26 PM »
i have said this before but i don't see what all the grief is about neck dive. man up and play your bass and let guitar players and momma's boys worry about such stuff. :P
Re: Neck heavy?
« Reply #3 on: June 01, 2010, 06:14:05 PM »
It's a really big deal to me. I have no problem playing a 10 lb. bass if it's well balanced but I'll sell a lighter bass if it dives. It's not just about comfort, it's about playability. The worst I ever had was my Fender Coronado Bass. It was light but if you took your hand off the neck it would dive and the bass would rotate outward. I won't put up with having to wrestle the bass in order to play it.
Re: Neck heavy?
« Reply #4 on: June 01, 2010, 07:26:33 PM »
I figure that I can often fix moderate neck dive - usually with the right strap - but I can't make a bass lighter.  I have a 9.5 pound Jazz that's on the outer edge of the weight I'll work with.  Fortunately Jazz basses balance well.  Heavy AND neck diver would be an instant disqualification.
Aussie Mark
Re: Neck heavy?
« Reply #5 on: June 01, 2010, 08:53:25 PM »
I posted this because I've never found alleged neck heavy basses to be a problem at all, whether it's a Thunderbird, Ripper, EB4L, or LPB.  A wide leather strap with suede backing, coupled with not wearing the bass too high equates to zero neck dive for me.
Cheers
Mark
    • Myspace page
Re: Neck heavy?
« Reply #6 on: June 01, 2010, 09:55:24 PM »
I don't have any real worries with neck dive. The often mentioned wide strap with the rough (suede) back stop my T-birds from sliding around (not that they really do anyway).
Re: Neck heavy?
« Reply #7 on: June 01, 2010, 10:20:40 PM »
That works by transferring some of the imbalance to your body. If that works for you, more power to you. It doesn't work for me. I want the bass to be balanced to begin with.
Aussie Mark
Re: Neck heavy?
« Reply #8 on: June 01, 2010, 10:29:43 PM »
No Gibsons for you.
Cheers
Mark
Re: Neck heavy?
« Reply #9 on: June 01, 2010, 10:32:02 PM »
Re: Neck heavy?
« Reply #10 on: June 02, 2010, 10:20:05 AM »
I've always felt that Dave has a distiinct Fender bias...
Mark... you don't think that nice pink smilie you use is girlie enough...? (no pleasin' some girls... :P)
Re: Neck heavy?
« Reply #11 on: June 02, 2010, 12:45:15 PM »
Sometimes I get neck heavy if I'm in a meeting with words like "quarterly blah blah...", "mandatory this or that", "employee engagement", or "methodology" in the title.  Oh the head-dive!
Despite this ergonomic defect, I still keep myself around  :)
Re: Neck heavy?
« Reply #12 on: June 02, 2010, 04:07:06 PM »
No. I like Fenders in general but I've played my share of unbalanced Fender basses, like the Coronado I mentioned.
Re: Neck heavy?
« Reply #13 on: June 02, 2010, 07:51:02 PM »
I suspect that Coronado wasn't a lot different than many hollowbody basses.  Their bodies generally don't weigh a lot, so the necks - even short scale - tend to dive.  I've worked on that with my Univox bass...it's not as bad as you describe the Coronado being.
Re: Neck heavy?
« Reply #14 on: June 02, 2010, 10:10:20 PM »
The Coronado was in a league of its own.
