15" tone rings
Started by sniper, February 15, 2010, 03:35:11 PM
TILT...!
(I knew I should have listened more at college...  ;))
There are some people that seriously know their stuff round here... hats off...
Quote from: sniper dog on February 22, 2010, 07:49:14 AM
here is the comparison of the second modification to a sample Fender circuit that was loaded in the calculator:
mine is the top line. JJ (tesla) and EH both making the 12DW7 again.
You'll want to move that low frequency "hump" farther to the right by using a higher value cap for bass, probably .47 microfarad, maybe even as high as 1 microfarad. You really want to try and corner the mids at 400 Hz. Right now, they're at about 30 Hz.  As it stands now, you're scooping out almost all the low end and midrange definition.
Quote from: Kenny Five-O on February 22, 2010, 01:03:48 PM
TILT...!
Don't let 'em scare you Kenny. When it's time to talk idiot stuff, you know I'll be there for ya ;)
...if you all only knew what a redneck I am. The only reason I care so much about amps is that when it's time to play out and I roll into someplace, it's a good feeling to tell the soundguy, "Don't worry about the bass sound; I've got it covered, and if you piss me off with too much kickdrum through the subs, I will make you pay."  8)
#19
working on trying to flatten it out some
TILT...!
You and me, Kenny, you and me.  A PhD does me no darn good in this company.  I try to remember that a grad degree and a buck will get me coffee in a cheap restaurant.
PhD...? bummer, Al... can you get anything for that...  ;D
Quote from: Psycho Bass Guy on February 23, 2010, 08:56:25 AM
YEEEEHHHHAAAAAAW!!!!!
I'm just looking forward to trying to figure out the feedback issue with my '68 Marshall 50...  :o (low on the priority list at the mo - still gotta re-cap the Hiwatt, in my spare time...  ;))
... and Rick, I appreciate that...  :P
Quote from: Kenny Five-O on February 26, 2010, 06:09:33 PM
I administer beer as needed, then go crawl under a car and work on it.  Or maybe it's the other way around. :P
#23
okay, i've been playing with the tone stack and to get it flat is not hard. to get it flat with a fairly wide sweep range is truely a bit_h! or to get it flat wih any db difference deeper than a -10 is anyway. i'm thinking that is the purpose of the sweep though, am i not right? at least that is how i understand the plan.
Jack Ryan: [imitating the Admiral] "The average Rooskie, son, don't take a dump without a plan."
i'm still grinding.
btw, the tonestack calculator i am using is the Duncan's tone stack calc. prolly not the best but almost understandable for a dyslexic like me.
#24
this is my latest effort to flatten the mid low, low hump and still have an acceptable sweep: the controls are at a flat 5
the sweep: the controls are at both extremes of the ranges for all three, treb, mid and bass
is this more like it should be? the mid range actually has some effect vs a Baxandall but i don't want it sounding like a Marshall. i suppose that could be considered a success but.....i'm actually thinking of chucking this clunker and using a Baxandall circuit getting rid of the mid pot and leaving the volume after the first gain stage in the name of simplicity.
That is very similar to a Marshall curve, and you're seeing why Ampeg used the Baxandall. I actually think the Marshall EQ wouldn't be a bad thing. Marshall's get brash from their driver and power sections being current starved, which won't be an issue with your amp. Right now, I'd say the voicing falls between Sunn and Ampeg, but with better "hi-fi" performance.
Quote from: Psycho Bass Guy on March 02, 2010, 09:39:48 PM
shouting "gawd" during organisms (a hillbilly word) is not exactly worship but in this case it is close!!! now to try and finish the design and start to work on the amp section and a marriage of the two.
i won't mess with this anymore then ... unless absolutely ness.  ;D thanks
