Author Topic: Advice on routing new pickup recess  (Read 2647 times)
« on: December 29, 2009, 03:28:18 PM »
I'm about ready to have a go at routing the new pickup recess for the T-Bird pickup on my EB-0.
Any advice on whether I should make a template for the cavity, or free-hand it with a carefully created outline on the body?  I may have to tweak the existing pickup cavity as well.
Re: Advice on routing new pickup recess
« Reply #1 on: December 29, 2009, 06:52:23 PM »
I would make a template, and depending on the situation I might plug the existing cavity.
« Reply #2 on: December 29, 2009, 07:19:30 PM »
Template and test it on some scrap first.  Also make sure you allow for the thickness of the finish when sizing the template.  The perfect snug fit becomes a PIA once you add finish - or so I'm told  :-[ :rolleyes:
« Reply #3 on: December 30, 2009, 07:09:55 AM »
+1, template and test.
« Reply #4 on: December 30, 2009, 12:36:39 PM »
+2! After working in the case shop here for the past 13 years, I can't BELIEVE the things I used to do free-hand with a router. Templates rule!
« Reply #5 on: December 30, 2009, 01:34:46 PM »
Sounds like great advice.  I'll flip that PU upside down and trace, then figure out how much wider the template needs to be to allow for the bit and bearing.  A few 2x6 chunks can give their all for practice and adjustment.
« Reply #6 on: December 30, 2009, 01:36:55 PM »
Agree with all of the above ! Template and test !
Bionic-Joe
« Reply #7 on: December 31, 2009, 04:59:30 PM »
ALWAYS use a template and then test. Freehanding is for other purposes. You'd seriously regret it if ypou try to freehand it. My 2 cents.
« Reply #8 on: December 31, 2009, 06:32:58 PM »
I can't remember, are these the standard guitar humbucker size from a LP Bass or the wider ones from a T-bird? If it's the former, you can probably find an accurate template .pdf online.
« Reply #9 on: January 02, 2010, 07:08:27 AM »
Dave's right.  If the pups are the smaller LP pup size, you can buy the templates cheaply enough on eBay or Stew-Mac.
« Reply #10 on: January 02, 2010, 12:28:03 PM »
I've emailed Stew-Mac asking them if their Humbucker Pickup Routing Template (#1094) is a match to my T-bird pickups.  My pickups have dimensions of 2 3/4" wide, 1 1/2" top to bottom, and the mounting tabs on each end stick out about an additional 1/4".  We'll see what they have to say.
« Reply #11 on: January 02, 2010, 12:48:38 PM »
That's standard guitar humbucker dimensions, give or take a thousandth or two depending on manufacturer. Bartolini's page gives the dimensions as 2.75 in x1.52 in.
I found the attached routing template at the Tele forum, he did not put in the corner radii because he predrills the corners at 3/8 in. and uses a converted milling machine instead of a router. I can't vouch for the template dimensions but I can measure an opening in an old pickguard if you wish.
Of course, using a square template with a router still gives you rounded corners, just use the proper radius bit.
« Last Edit: January 02, 2010, 12:57:52 PM by Dave W »
« Reply #12 on: January 02, 2010, 06:06:16 PM »
Thank you very much, Dave!
That sure looks right!  That template just adds 1/16" in each dimension...and my measurement was a 'skosh (note highly technical language used for accuracy) smaller than the lines on the tracing I made.
If that's the case, I may buy the $6 template from Stew-Mac.  Howsomever, I picked up a chunk of masonite today and might try making my own...if I can find a couple hours to spare.
« Last Edit: January 02, 2010, 07:07:41 PM by Pilgrim »
« Reply #13 on: January 03, 2010, 07:15:35 AM »
You'ld need a template for the template...  ;)
« Reply #14 on: January 03, 2010, 01:40:20 PM »
This has not escaped me.  It would take a good deal of time to make a template from scratch - when one has never done it before.
