PARENTAL ADVISORY
The shorts are out... much to my wife's disgust...
Well, as a swansong for the original colours, and prior to the demolition of my shed (the veggie's lair, where many a vegetable has met it's fate...
Demolition...? yep, roof is barely up, and sides are bowing out... new concrete plinth over the next month or so, and then a nice metal hell-hole to work in...), and as I have a rehearsal tonight, I thought it was time I tried to get a little space to do the deed...
yep, an utter tip... I have no excuse... there will be no proper work until this is sorted...The first issue I had was that the MB was too big for the existing hole, which had been adapted for a DM EB replacement a couple of decades back, but long gone - could-not stand the thing, so I had to freehand-rout (Gawd only knows where most of my gear is in this dump) out the hole to suit the pup.
I need to do a lot of finishing off, but as I intend to do a complete strip down, I will finish off then...Bottomed out the space and then shimmed under the pup to suit, oh yeah, had to reshape the lower mount plate, as you can see... also had to rout away a section of her body (about 2/10"-5mm) to accommadate the cover, which would have been far too close to the strings...
A little packing was required front and rearWell, she's in... the screws are doing a nice temp job of pinning the pup in place...Finished off the temporary wiring today and fitted the original gold pup switch with one pot, hmm... a 6.5K RDA pup and a 30K Mud pup, straight through one standard volume pot...
So as it was so nice (and I may as well go hang myself as well as be dumb enough to run-up indoors) I set up outside in the garden (near 70f/20c) and run her up...
Bl**dy H*ll...! That IS Loud... there is no way I can run this through my fragile old Celestions, but have been doing some pricing up for a full set of 50w bass speakers to fill the Marshall cab, around £150 for Celestions, but still researching... The initial view is quite stark - quite simply AWESOME...! The difference between the pups is not subtle (the MB being so overpowering and the RDA being so clean, but where they meet is more than just interesting... I can't wait for this evening now when I can run the Hiwatt through a good 200w Carlsboro 2x15, and see what she can do...
And btw, I definitely do not have Mark's legs...
That's all the time I have right now... gotta go... And George... muchos gracias...
