Cheap Bass Strings
Started by lowend1, April 22, 2009, 01:55:45 PM
Freuds_Cat
Jamerson would be proud Pilgrim.  ;)
Digresion our specialty!
What Pilgrim hasn't told you is how many years that bass sat without being played.  8)
Come on, Al, fess up.
Geez, I'm proud n'humble.  But Dave has a great memory - the bass mostly sat in its case between 1973 and 1997.  I know my younger brother played it a bit in the 70's, but how much I dunno.
I will say that since I like the sound of this bass with these strings, I've decided that strings are forever until they break.  If I like 'em, I just keep 'em on.
Here it is.
Here's the headstock - and yes, you purists, it's not a '63 neck, it's a '72 neck because the truss rod broke in the original neck, and I had to re-neck it for a gig the next day.
Anyone know what brand of flats used this color of silk wrapping back in the late 60's / early 70's?  They seem to last pretty darn well!
Could they be GHS Precision Flats? They've had purple silks for years, but I don't know if they did back then. Company's been around since the mid 60s, IIRC.
No matter what kind or brand, I keep strings on until I think they sound bad or until they won't intonate properly.
I think I have some GHS flats on a Lyle SG-style...I'll take a look.
Strings may come and strings my go but flat-wounds just don't do it for me...
I've errr... broken quite a few... but I always keep any halfway decent old strings, just in case...
I have never broke a string, how do you achieve that guys? I mostly use fingers but sometimes I use a pick. Should I start using knife blades or something? :P
Black plastik is fantastik
I've never broken a bass string either. Guitar strings are a different story.
Freuds_Cat
I used to break either an A or an E about once a month for ages after I bought the Jazz before finally learning that the guy who had filed the grooves in the Badass saddles had made them too sharp. Had them modded and haven't broken a string in more than 20 years.
I led a dubious life playing mostly in three piece with vocals, playing a lot of chords to fill in during solos (the Hiwatt is handy for that as she has a built in volume switching circuit) and tended to be a bit rough so they tended to deteriorate quite quickly... that and the Tequilabird had a Badass bridge and pointy saddles...
My last band in the 80's (now re-formed) was/is much more restrained and I mostly play with my fingers these days...
I also discovered some oddball Rotosound strings which had the core exposed to go over the saddles - exceptionally bright but highly fragile - don't use them now although the Hohner still has three... as I said, I don't change them unnecessarily... though nothing as old as Pilgrim Al's ...  ;D
I checked the bass with the GHS strings (as far as I can recall). The silks are a dark purple and the windings on the old flats on that P-bass are closer to blue.  I don't think they have been exposed to enough light to fade to blue, so either GHS changed colors or it's some other brand on the P-bass.
If it's any help, all sizes of LaBella flats had royal blue silks back then.
AHA!!!  Justified or not, that would reinforce my faith in LaBellas, my favorite flatwounds.   ;D
