How many 4x10's around here?
Started by Pilgrim, March 09, 2009, 12:41:52 PM
Idle curiosity - how many people on here use a 4x10 as their primary cab, either with or without a 15 or other add-on?  I suspect that many of us have gone that route.
I have a new GK Goldline 4x10 that's my gig cab. I can add a Peavey 15" cab (with Eminence speaker) if needed, but frankly we're not that loud a band, so there isn't really a need for it most of the time.
(stock photo...)
I use 4x10s only. First a Kustom Tuck 'n Roll reissue, than an Ampeg, than the Orange and now a Hiwatt with Celestions. No room for an extra 1x15...
Saf
do you still get a lot off bottom in your soud with an 4 x 10"?  I use 4 x 12" or 4 x 15" cabs and have little experinence with 4 x 10" played a couple of them on shared backline gigs but just have the idea that a cab with bigger speaker has more "power" in the sound.
pbrocker56
I'm in the market for a 4x10. How is the Goldline Pilgrim? I'm looking at either the GK Goldline or BLK for a 4x10.
I'm currently using a Kustom 2x15, and I think its a little too boomy for me.
Are you real, Frank!?
hollowbody
It's been quite a few years since I've owned 10" speakers in general.  I either use Acoustic 4x15 or 6x12 cabs.  Sometimes I think of going back to a 4x10 for the portability but then I sober up.  ;)
10s? You want 10s?
The one on the left is a 1970s Ampeg B40 with Peavey Scorpion speakers...
Quote from: pbrocker56 on March 09, 2009, 05:51:24 PM
I have been using a single Peavey 15, but I didn't get the note definition I started to crave.  I think my ears are becoming more discerning.
I ran into the Goldline at a GC sale last summer, and I compared it with some other 4x10s there.  I think the bottom end is quite strong, and that the overall sound provides low-end guts but preserves note definition.  I personally like the sound of the Hartke metal cone speakers I've heard, and there is obviously something in common with the metal cones in the GK speakers, but I thought the GK cab had a warmer sound than the Hartkes. I suggest doing some side-by-side comparisons with other 4x10s, and I believe the Goldline is a GC exclusive, so they should have others handy to compare with....but the sound was a winner for me.  The drawback is weight, as the cab is around 90 pounds which is on the heavy side for a 4x10.  If I ever need it for a large venue I can pair the GK 4x10 with my Peavey 15" cab..but that's not normally the kind of gig I play.
There aren't many reviews of the Goldline around yet, but since a few of them suggested that longevity of the speakers might be an issue, I bought the GC extended warranty - something I very seldom do. Probably a waste, since I don't really plan to push the cab near its max rating.
If you try out the Goldline, let me know what you think.  I like the sound a LOT.
@ Saf: I have no room in my car for anything bigger than a 4x10. I like 4x12s though. But if I want I have thundering lows with the 4x10, but I always prefer a more pushing mid-ish sound.
Saf
I drive an nissan micra and I can get my 4 x 15" cab in the back of it, my amp, two bassguitars and a suitcase with cables etc goes with it as wel. Haven't jet tried to put the bassman 4 x 12" in the car but I think it fits as wel.
I have a Twingo and a guitar playing girlfriend in my band. So:
- 4x10
- Bass head
- Back up bass head
- Fender Deluxe amp
- Guitar in case
- Guitar in gigbag
- Bass in case
- Bass in gigbag
- Effects/cable case Chris
- Effects/cable case Loes
- Loes
- Chris
- And sometimes drum gear or VJ gear:)
Well, I have two GK SBX 4x10's they're the only cabs I use, I think they're pretty articulate and tight, and not boomy.........Definately easier for me to roadie than a single 8x10 (my sissy girlie arms!) and they fit into the Subaru better too.
Saf
I used to have an twingo, loved the car. It is sadly passed away last year. I used to transport my bassman 4 x 12" cab, the bassman head, Two of my bassguitars, a combo amp for the banjo player, the banjo and some drumkit gear. It always amazed me how mucht you can put into a twingo. Much more than my micra. (it's my wife's car, I normally drive an daithatsu cuore, I can't get a cab into that one.
pbrocker56
Quote from: Pilgrim on March 09, 2009, 09:05:59 PM
Thank you for the info. I went to GC just yesterday, and I tried an Ashdown 4x10, and it seemed too warm for me. It was one of the higher end models. I also tried a Hartke, but I just couldn't dial in the sound i wanted.
They didn't have the Goldline 4x10, but they had the 2x10 and the 8x10, so I played them just to get an idea.
WOW! I found exactly what I was looking for. I played a Mexican P-bass off the wall, and a Gibson SG bass and I got close to perfect on what I wanted out of both the 2x10 and 8x10, tone wise.
I'm still looking at different cabs and makes, but if I can, I'm springing for the Goldline.
Another 4x10 that has been out for a year or so is the Acoustic.  The reviews I've read indicate the Acoustic 200W head is a very strong, loud 200W...but I haven't read much about the speaker cabs yet. Most GC stores carry the Acoustics.
If the Goldlines sound good to you, I'm pleased.  They sound good to me.
 I have a Marshall 4x10 that needs to be reloaded, I blew all four drivers at a show a few years ago. :sad:
