Five string Ricks, what can you tell me about them?
Started by Blazer, February 10, 2009, 05:00:37 PM
Blazer
A friend of mine has his eyes set on a Rickenbacker 4003/5 five string in jet-glo.
I promised him that I would enquire about those basses and so I ask of you guys what can you tell me about Five string Ricks, what should we look for and what should we look out for?
They were discontinued, and since the 4004Cii/5 was also discontinued, it's been several years now that Rickenbacker don't offer 5-string basses of any model. So the 4003S/5 is sought after and prices on eBay are going steadily up.
S/5's were basically modified 4003S's (the non-deluxe model, with dot markers, no binding on the neck and body, and mono output). Tailpieces are modified 4-string units, with a 5th hole drilled between the A and D string holes. The necks were the same width (or almost the same) as the 4-string 4003, so string spacing is tighter than other modern 5-stringers. Some owners have modified the bridge to slightly wider spacing, by using new saddles and putting the slots off-center.
Over at the RickResource forum there's a picture thread on S/5's.
4003S/5 - The necks are skinny and the strings are too close together for most people, myself included.
4004Cii/5 - Super rare, very wide neck, pickups aren't wide enough, so you get weak B and G strings.
Buy a Spector!  :o
And this is coming from a huge Ric geek.  ;)
ilan, does Jeff Rath not post at RickResource anymore?
Black plastik is fantastik
I have one of them. The close string spacing is a matter of taste, as a pick player I don't mind. Yes, the neck is a tiny bit wider and thicker, the headstock larger. Still balances ok, kind of levels out in horizontal mode. But both the B string and the G string are noticably weaker than the other three strings and no amount of pick-up tilt tinkering will cure that to full satisfaction. Perhaps not the greatest idea to turn a bass that is not even regular long scale into a five string, the B string does wobble a bit and its sound is not as "there" as the E string's. So in effect, you have soundwise a 4 string bass (with a weak G) with additional access to some muted low notes if needed. There is a reason (or a couple) why people did not queue up to buy it.  ;)
I haven't heard until now of weak G and B strings on a 4003s/5. This complaint is common for the 4004Cii/5 with the wider string spacing and 2000 Series pickups.
Quote from: uwe on February 18, 2009, 10:12:23 AMStill balances ok, kind of levels out in horizontal mode.
I hate when this happens. Maybe Gibson aficionados can live with some neck dive, but Rics were the first basses with an extended upper horn, they should balance perfectly on a strap.
The explanation is kind of simple to me, the pole pieces are elevated toward the center, the lowest ones being the G and B. Volume differences could probably be cured if they were individually adjustable as with the new pups.
I'd ask Sérgio Silva, a Ric pickup expert. I'm sure he can modify the stock pickup to have perfect string-to-string balance. He's in Lisbon, Portugal, that's not too far from you. I don't have his email but I can PM him thru the RickResource forum if you want.
Yeah, why not. I always wondered how you could get those pole pieces to budge.
I sent him a PM. Will update as soon as I hear something new.
Blazer
That buddy of mine eventually went home with a normal 4003S in Jet-glo, he strung it up in B-E-A-D and it sounds absolutely brutal.
