Author Topic: 1966 EBSF-1250 Double neck with Fuzz  (Read 322 times)
Re: 1966 EBSF-1250 Double neck with Fuzz
« Reply #1 on: February 24, 2024, 06:22:20 AM »
I wish Gibson had shipped that behemoth to Jimmy Page.
  • Low Impedance LP's
« Reply #2 on: February 24, 2024, 08:00:20 AM »
Wow! $50,000 with a non functioning FuzzTone circuit! I was at Carter Vintage a few years back, a very nice store. Gruhn’s & Carter’s are only about a block apart.
« Reply #3 on: February 27, 2024, 08:25:00 AM »
I was going to be sarcastic and say that the fuzztone unit was put there just as a counterweight, but then I looked at the specs — 11.6lbs.! Very light for a 4/6 double neck. I have a '79 P that's heavier.
« Reply #4 on: February 27, 2024, 08:42:12 AM »
"Wow! $50,000 with a non functioning FuzzTone circuit!"
Those things are hell to repair, really tricky and you don't get the electronic parts anymore.
« Reply #5 on: February 27, 2024, 11:50:02 AM »
Damn. I assumed it would be six components and a battery. Presumably some obsolete transistors are involved?
D.M.N.
« Reply #6 on: February 27, 2024, 12:17:59 PM »
It is a simple circuit, less than 20 components including the pots, values and transistor types varying by version (FZ-1, FZ-1A, etc, FZ-1S being quite different). The original transistor type can still be bought, though they are obsolete, and newer ones might not sound quite like the old ones, but you can still build the circuit very cheaply and use other transistors with similar specs. That said, having not seen the layout inside the control cavity, no idea how easy or difficult it would be to work on the original circuit.
« Reply #7 on: February 27, 2024, 05:01:58 PM »
There is also continuous drain on the battery, so even if you don't use the fuzz, the batteries give up after a few months. Very steampunk.
D.M.N.
« Reply #8 on: February 27, 2024, 05:49:42 PM »
True! I suppose you could rig up a battery disconnect using a stereo jack on the instrument or potentiometer with an off click. And it takes AA! So that's fun and goofy.
« Reply #9 on: February 28, 2024, 07:56:43 AM »
No matter how well the circuit works, it still sounds like an “Electric Fart”! It would be nice if you could use the FuzzTone on both the bass & the guitar………
« Reply #10 on: February 28, 2024, 09:34:58 AM »
It's very limited in usage, a novelty effect more for recording than for playing live.
