Author Topic: Christie's offering Les Paul's Number One  (Read 1552 times)
Re: Christie's offering Les Paul's Number One
« Reply #1 on: August 19, 2021, 02:31:43 PM »
Great release.
What were the coils in the switch pocket and between pickups for?
« Reply #2 on: August 19, 2021, 10:31:01 PM »
Tom Doyle would know. I don't.
  • Low Impedance LP's
« Reply #3 on: August 23, 2021, 06:24:05 AM »
It will be interesting to see what it sell for……..
« Reply #4 on: August 23, 2021, 08:30:53 AM »
Great release.
The thing in the switch pocket is probably just the switch, all taped up to keep dirt out.  They were bigger back then.  The thing between the pups, I would guess, is a dummy coil for humbucking.  Anything tone control related should be smaller and located in that roomy control cavity to minimise noise/keep leads to pots/jack etc as short as possible.
« Reply #5 on: August 24, 2021, 05:09:25 AM »
Thanks Jake!
I thought the  center coil might be a dummy but no clue about the switch.
« Reply #6 on: August 24, 2021, 07:54:16 AM »
I suspect the big coil in the middle is the dummy coil for the bridge pickup. And the coil next to the switch is the dummy coil for the neck pickup.
No switch would need a coil, as far as I know.
« Reply #7 on: August 24, 2021, 09:08:26 AM »
The "coils" being 2 diff sizes, and one being in the switch cavity vs between the pups, really makes me skeptical of that they are both dummy coils.  There is no need for separate dummy coils, and the best place for a shared coil is between the pickups.  I really think that's just a very large taped up switch.  Not even that much larger than a modern L style LP pup switch, just all taped up.
« Reply #8 on: August 27, 2021, 01:43:46 AM »
However it looks like a heavy gauge coil winding exposed where there's insulation tape missing.
« Reply #9 on: August 28, 2021, 01:11:54 PM »
Maybe les thought it would shield the cavity or something.
