Author Topic: Neat little mod idea  (Read 1516 times)
« on: August 05, 2021, 09:44:48 AM »
Look at the quick release bridge cover on this Shergold Marathon. I think I should modify a P bass cover (w/ foam mute) like that.
Re: Neat little mod idea
« Reply #1 on: August 05, 2021, 05:03:31 PM »
Clever and an easy mod.
« Reply #2 on: August 05, 2021, 08:23:01 PM »
If you're one that can use it, it's a nice idea.
« Reply #3 on: August 06, 2021, 12:27:20 AM »
I prefer the sound of over-string foam mute, playing with a pick it's different from under-string mute. For some reason only over-string keeps the click. With fingerstyle there's not a lot of difference. So I have one P with the cover and fixed mute, and one without. All lever-engaged mutes are under-string. This is the first time I see an over-string mute that can be removed in a second. Worth a try, I think.
« Reply #4 on: August 06, 2021, 11:04:24 AM »
Handy for sure.  It's either that or get a Gibson 2 point with switchable mutes in there ;P
« Reply #5 on: August 07, 2021, 12:08:11 AM »
That's an under-string contraption.
« Reply #6 on: August 07, 2021, 06:17:45 AM »
I still have the original foam mute from my '63 P.  Its the over-string, with adhesive holding it to the underside of the cover.  I think it wouldn't interfere with that idea to make the cover removable. The strings press grooves into the foam after a while.
« Reply #7 on: August 08, 2021, 07:46:28 AM »
IMHO the original foam is great, gives that clicky sound we immediately recognize. The closest are weather strip, and what Fender sells as "pickup height foam strips".
« Reply #8 on: August 08, 2021, 04:10:36 PM »
Yup, 3M weatherstrip is the best match.
