Author Topic: external -15db input pad for an active bass?  (Read 1541 times)
pilgrim9
  • Jr. Member
« on: March 14, 2021, 11:30:12 AM »
Hi, all of my basses are passive and I just got a Gibson LPB2 that has Bartiloni actives with no on off for the preamp. The signal from the Gibson is so hot I have to turn the input gain to where it just turns on to make the bass useable. I use 3 older amps in my rig and none have the -15db input pad switch for a active bass like newer amps. I can get it to work by rolling the volume back on the bass but there is treble loss. I tried a EH signal pad and that thing really kills the tone, completly worthless. I am looking for a external -15 db pad I can just turn on and off for just when I use the Gibson, any ideas?
If you push something hard enough it must fall over.
Re: external -15db input pad for an active bass?
« Reply #1 on: March 14, 2021, 04:44:00 PM »
You can easily build in a pad to a cable or a barrel connector.  Just a coupla resistors. I am not aware of any mass marketed products for this but have seen various custom builds.
http://www.uneeda-audio.com/pads/
Middle left diagram (unbalanced symetrical).  You can get female 1/4" to female 1/4" in barrel connectors vs the XLR ones shown.  Or use a nano size pedal box. Neutrik even has a modular series of parts specifically for making stuff like this but a tad expensive last I checked: https://www.neutrik.com/en/neutrik/products/accessories/modules
pilgrim9
  • Jr. Member
« Reply #2 on: March 16, 2021, 08:57:19 PM »
Thanks for the help but just reading the info to do the math gave me a headache, way over my abilities.  I am really looking for something pre built with an easy on off. I do have friend that might be able build what I am looking for, have to give him a call. thanks again!
« Reply #4 on: March 17, 2021, 10:28:54 AM »
No, that's a DI.  A pad is a fixed attenuator.
« Reply #5 on: March 17, 2021, 12:42:50 PM »
Thank you.
pilgrim9
  • Jr. Member
« Reply #6 on: March 23, 2021, 05:00:30 PM »
I had looked at DI's also but the pad only effects the loZ out not the pass thru signal unfortunatly.
« Reply #7 on: April 02, 2021, 02:33:47 PM »
This oughta work.
