Author Topic: Big Brass Beastie - but who made it?  (Read 1425 times)
« on: February 12, 2021, 06:51:00 AM »
Hi Gang,
I bought this chunky brass bridge off of Ebay last week:
With a bit of loving I was able to get it pretty cleaned up:
Does anybody recognise it? It is sort of patterned somewhere between a Badass I and II, but probably bigger in every way. It is drilled out as an 8 string bridge (I think?) as it has smaller holes at an offset angle to the main string holes. It is a toploader only design, with four mounting holes at the corners of a rectangle.
I've had to re-slot the saddles as it was an ugly mix of random grooves on each one except the low E.
The build quality reminds me of the bridge I took from a Westone Thunder bass. The longer you look the more you realise that none of the geometries are perfectly square, and the flat surfaces are all wee bit 'wobbly jelly'.
It is a punishingly heavy bridge at 372 g (13 ounces).
Anybody seen one of these before?
Re: Big Brass Beastie - but who made it?
« Reply #1 on: February 12, 2021, 08:13:00 AM »
I have not, but it does look like a Badass 1 knockoff like you said.
« Reply #2 on: February 13, 2021, 10:02:46 PM »
It does look similar to a Badass I but I wouldn't call it a knockoff because it's brass.  All three versions of the Badass were cast zinc alloy.
« Reply #3 on: April 08, 2021, 04:00:32 AM »
   Brass and mass were king in the late 70s. It could be Mighty Mite, Schecter etc.
« Last Edit: April 16, 2021, 03:47:10 AM by godofthunder »
clankenstein
  • Never Gutless!
« Reply #4 on: April 09, 2021, 05:04:28 PM »
I cant find any reference to it on line, but I bought a brass F spaced bridge by Dimarzio around !984 I think. Different Bridge saddles, more like a Hipshot.
Louder bass!.
