3-point bridge: how best to adjust the posts?
Started by slinkp, March 13, 2020, 09:11:24 AM
Do you just use a gigantic screwdriver?
Or what?
Do you loosen the strings first?
I'd like to drop the action on my new blue DC by a hair, maybe just a millimeter.
Don't wanna screw anything up!
If you wanna lower the action just a bit it is not necessary to loosen the strings. But it doesn't hurt to do so anyway.
If you wan't to raise the action, It is best to loosen them.
I use a large screwdriver indeed.
First lower the two outer studs.
And then adjust the middle one to keep the bridge parallel to the body.
The larger the screwdriver the better, it shouldn't have any room to wiggle. And in that case, strings can stay as they are. If you use a smaller screwdriver (some people even use coins), because there is nothing better handy, detuning a little makes things easier. If you want to drop action just a little for all strings, adjusting the middle screw will do unless the two larger screws are already higher and your bridge is slanted forward which it shouldn't be.
Send a pic of your bridge and we can tell you what to do.
FrankieTbird
Good tips.  Also, I like to keep the front of the bridge just slightly higher than the back, not perfectly parallel to the body.  Increases the break angle over the saddles and slightly counteracts the tendency to pull the inserts out of the body.
Or you could get a Hipshot Supertone and live happily ever after.  :vader:
Quote from: Dave W on March 13, 2020, 09:17:35 PM
Yeah, love it on my Thunderbird.
There is a special tool for this too, a right size screwdriver with a cylinder around it and short handle. I think stu-mac sold them, but these days you probably find them on ebay as well.
Quote from: amptech on March 14, 2020, 01:02:19 AM
https://www.ebay.com/i/180905582393
I think the Hipshot Supertone looks clumsy on a Tbird. Because it is wider than the raised middle section of the body.
I'd prefer the Babicz three point replacement, which is an excellent bridge that can be adjusted for intonation, saddle height and string spacing. (the latter a bit limited)
Quote from: Basvarken on March 15, 2020, 03:34:21 AM
How can the Babicz be adjusted for string spacing? That's the biggest reason I got the Hipshot, plus the Babicz didn't exist yet.
The saddles (the rotating part) can be pushed sideways a bit. But as I mentioned, the travel is limited.
Not that you'd really need to, because the bridge is made as a drop-in replacement for the 3 point which has a non adjustable string spacing.
Quote from: Basvarken on March 15, 2020, 10:06:34 AM
Ah, thanks. But it's a want thing, not need. On my Hipshot I narrowed the spacing as much as it would go because I like that.
So far I really like the 3 point...except the part where the saddle falls out when you are changing strings...that is maddening.
I can see how you might not like the Supertone's look on a Tbird. On a flat surface either one looks fine to me.
