Author Topic: Poor sweet baby.  (Read 11413 times)
Re: Poor sweet baby.
« Reply #60 on: October 14, 2016, 10:55:09 AM »
 :popcorn:
« Reply #61 on: October 14, 2016, 02:46:24 PM »
Here's the general idea: Two straight cuts, then grafting on new mahogany using original Titebond.
Bionic-Joe
« Reply #62 on: October 14, 2016, 03:31:10 PM »
Or steam it out and make 2 new wings....
don't forget the taper....
« Reply #63 on: October 14, 2016, 03:35:46 PM »
Explorer wings... thru-neck explorer... :vader:
« Reply #64 on: October 14, 2016, 06:00:21 PM »
In my mind I had you doing two new (full) wings but your plan preserves more of the original bird. I like that!
« Reply #65 on: October 14, 2016, 10:03:06 PM »
Makes sense, and you can keep the cutoffs for possible future use.
« Reply #66 on: October 15, 2016, 04:32:31 AM »
Making the male 'V' cut in the wings requires a shaper and custom cutter (neither of which I currently own or need).  I'm looking to complete the work as economically as possible with the tech I have.
No matter how correct the wing restoration the center section won't be.  Maybe I could see the point of the extra work and expense if it were.  Doing it this way still allows someone else to do a total wing graft, but it won't be me.
« Reply #67 on: October 15, 2016, 08:27:33 AM »
I think you plan works just fine.  How are going to make the cuts?  In my mind a simple sled, or jig, for a table saw does the trick.
« Reply #68 on: October 15, 2016, 08:50:47 AM »
I'll bandsaw the cuts with a 3TPI blade, then 'joint' using a bottom bearing 1/2" straight router bit against a clamped on straight edge.  Can't use my actual jointer, unfortunately.
I've owned at least six tablesaws, from my current $129 15 amp, 10 inch to a 7hp 16 inch, 10 foot slider with 5 inch scoring blade.  I much prefer the bandsaw and a jointer for instrument work.  I make rough crosscuts using a 7" circular saw or Bosch jigsaw if necessary. I haven't used the table saw in years, it has a 2'x8' piece of plywood clamped to the top of it, it's my main workbench.  Maybe if it wasn't so underpowered.
« Last Edit: October 15, 2016, 08:56:13 AM by dadagoboi »
« Reply #69 on: October 17, 2016, 07:31:15 AM »
Finally, a 13-ply body TBird!
« Reply #70 on: October 17, 2016, 10:24:24 AM »
Good plan. I'd use the cutoffs to plug the P rout.
planetgaffnet
    • Nancy Johnson
« Reply #71 on: November 10, 2016, 02:00:46 AM »
Any progress here?  I woke up at about 6.00am this morning and it was the first thing I thought about!
« Reply #72 on: November 10, 2016, 07:47:10 AM »
No, sorry.  Other work in front of it.
