Gear Discussion Forums => Gibson Basses => Topic started by: godofthunder on January 07, 2013, 10:23:32 AM
Title: New Gibson EB bass mini review
Post by: godofthunder on January 07, 2013, 10:23:32 AM
  Ok mainly to satisfy Dave I checked one of these out at the House of Guitars. Overall build quality is very good on par with my Worn SG bass. The bass is finished in a overall matte, I dig the mustard /ketchup bust on the two piece Ash body. My immediate impression was that of a Moserite with a fat long neck. The neck is one piece maple with a rosewood fingerboard. The pickups look like standard TB Plus housings but with eight large pole pieces each. The bass is tight and focused, none of the blur one associates with a Gibson. The bass suffers from EB4-itus. When you bend the strings past the pole pieces there is a noticeable drop in volume. This would be a deal breaker for me but if you don't bend notes you may never notice it. The bass is a bit neck heavy as the body is quite compact. Overall the bass is well built, has a lets say unique vibe and is priced reasonably. Not my cup of tea but it may be yours.
Title: Re: New Gibson EB bass mini review
Post by: ilan on January 07, 2013, 11:50:04 AM
Quote from: godofthunder on January 07, 2013, 10:23:32 AM
Button-top Ric neck pickups do that too. You can use this unfortunate feature for a "tremolo" effect.
Post by: uwe on January 07, 2013, 02:36:40 PM
Ouch, the older I get, the more I bend. I used to laugh about Billy Sheehan's constant vibrato on every note he plays, now I tend to do it myself ...  :-\
Post by: Hörnisse on January 07, 2013, 08:18:24 PM
Quote from: uwe on January 07, 2013, 02:36:40 PM
I'm doing it more as well.  I think it is due to the round core and light gauge Hi Beams that I use.  It took me a while to get used to the floppiness but I cannot go back to hex core strings.  Even the lightest gauges feel too tight.  :o
Post by: uwe on January 08, 2013, 09:47:19 AM
Over the decades, my left hand touch has become stronger, my right hand one lighter!
Post by: TBird1958 on January 08, 2013, 12:59:18 PM
My left hand technique is rather clumsy................ :-X
Post by: Highlander on January 08, 2013, 04:05:23 PM
Never had a string bending problem with any of my fretless's...
Post by: Dave W on January 08, 2013, 08:46:25 PM
I had a chance to sneak downstairs and play for a while. First impressions: on a 2" cotton strap, there's a slight tilt. I wouldn't call it neck diving. I'm sure it's because the upper horn isn't as long as on a typical Fender-inspired design. The tip of the upper strap button is opposite the 14th fret; by comparison, on my MM SUB it falls about halfway between the 11th and 12th frets.
Unlike Scott, I did not hear any significant dropoff in volume when bending, even doing half-step bends with my left hand and really trying to pull the string off the poles with my right. Then again, I'm not a string bender, maybe it's just a matter of different technique.
The neck profile is comfortable and not too thick front to back. The sound, well, it's definitely not a T-bird but it's certainly no MM either, despite the MM look of the pickups. Not muddy at all, even with the neck pickup soloed. IMHO clearer and not as midrangy as a modern or Bicentennial 'bird, more fundamental, nice highs but not as crystal clear as one would expect of a Fender or MM. All in all a nice tone. I haven't pushed it hard so don't know how aggressive it can be.
Using the highly scientific method of weighing myself with and without the bass, it's about 8 1/2 lbs., compared with 10 lbs. for my poplar SUB, which is a slab body. As you can see, it really isn't compact, not much difference in the body sizes except for the upper horn. I'll take better pics with some daylight coming into the basement later
(http://img.photobucket.com/albums/v104/davepix/Basses/IMG_0206_zpsc07c3771.jpg)
Post by: uwe on January 09, 2013, 02:48:03 AM
Sounds like they retained a Gibsonish tone, just a bit more modern. Which I guess makes sense, if you want an EBMM or Fender sound, buy one!
It does look more petite on pics than it can be judging by size comparison to the Sub.
Post by: Dave W on January 09, 2013, 10:38:07 AM
The shorter horn makes it look more compact. Other than that, it's actually larger than the SUB, which is a slab bodied Stingray. It's about an inch longer from the end of the fretboard to the butt end and about an inch wider measured at the lower bout and across at the treble side horn. Doesn't feel big, though.
Post by: wagdog on January 11, 2013, 05:36:10 PM
Has anybody played with the coil taps yet?  I'd like to know how much of a difference they make switching from humbuckers to singles.
Post by: Dave W on January 11, 2013, 10:16:48 PM
Quote from: wagdog on January 11, 2013, 05:36:10 PM
Yes, I had a chance to play with it a lot longer today. I expected more of a single coil sound without any radical differences, and it was as I expected. Nothing out of the ordinary but it does give you quite a bit of tonal versatility, especially for a passive bass.
So far, my favorite combo is the neck pickup on coil tap with the bridge pickup in HB mode. The neck alone in SC mode is quite nice too, and low noise for a SC.
Post by: uwe on January 12, 2013, 08:34:24 AM
A Gibson bass with variety?
Is nothing sacred?!
Post by: patman on January 12, 2013, 08:54:06 AM
That sounds like a pretty darn good bass.
Post by: Dave W on January 12, 2013, 09:39:50 AM
It is.
BTW, the coil tap positions are also rw/rp so they're fully hum-cancelling when they're both turned up. But even singly the noise is much lower than, say, a Tele. Must be well shielded.
Post by: Dave W on January 12, 2013, 09:49:02 AM
In case anyone is interested, the pickup dimensions are 3.7 in. x 1.7 in. No, I didn't use calipers, but that's very close. I don't know how that compares to TB Plus pickups.
Post by: uwe on March 01, 2013, 04:27:45 PM
I like the guy, kinda Frankie goes to Hollywood meets Monty Python. Ken, I had no idea there was even one limey store with as many newish Gibson basses, commendable!
http://www.youtube.com/watch?v=psezobkVBLE
Brighton, as they say, obviously rocks.
http://www.youtube.com/watch?v=j4-bh-YmbMQ&feature=player_embedded
This is hilarious;
http://www.youtube.com/watch?feature=player_embedded&v=nPgpkN4Tl_g
Post by: Dave W on March 01, 2013, 06:51:21 PM
You heard the man; the EB Bass is wicked.
Post by: uwe on March 01, 2013, 09:28:44 PM
Yes, and the Grabber Tribute is "a fantastic bit of gear".  8)
Post by: the mojo hobo on March 02, 2013, 08:58:22 AM
Quote from: Dave W on March 01, 2013, 06:51:21 PM
The last word in the vid:
Awesome.
Post by: TBird1958 on March 02, 2013, 11:34:20 AM
He doesn't begin to get anything out of that G-3...........
Post by: Highlander on March 02, 2013, 02:54:23 PM
Quote from: uwe on March 01, 2013, 04:27:45 PM
... Ken, I had no idea there was even one limey store with as many newish Gibson basses, commendable!
Never knew of the existance of this one (Brighton is both "green" and "pink" these days) and I try and avoid gas if at all humanly possible... ;)
Their website had reference to a "Gibson" evening on the 28th...
Gibson Factory Experience (http://www.gak.co.uk/en/gibsonfactoryexperience)
I have to say that they have a pretty comprehensive stock of Bass's, imo... Got to say that I'd be tempted by that Epi pro T'bird at that price, but then I glanced in the general direction of the shed...
Post by: Dave W on March 02, 2013, 03:44:05 PM
Quote from: HERBIE on March 02, 2013, 02:54:23 PM
Too bad it's already over. Uwe might have traveled there for it if he had known.
Post by: Denis on March 02, 2013, 07:29:33 PM
Quote from: TBird1958 on March 02, 2013, 11:34:20 AM
No shit.
Post by: uwe on March 03, 2013, 09:07:54 PM
Quote from: Dave W on March 02, 2013, 03:44:05 PM
Are you kidding me into self-frustration?! They've done those roadshows in Germany too - it's always all guitars ... Any question about basses would raise eyebrows only and establish the nerd factor of the questioner. Nein danke.
Post by: TobaccoRipper on March 04, 2013, 12:48:53 AM
Quote from: uwe on March 03, 2013, 09:07:54 PM
Fact! Don't ever ask in a german GC for Gibson Basses. The employees don't know anything about them and start treat you like a leper. Last week I was calling a GC and asked them if they could ship a Thunderbird to me to check it out (but mind I had payed the full price first before they would send it to my home). They said that they don't ship the bass because it's a Gibson and they are extremly rare. I start laughing and hung up the phone. That guy made my day.  ;D
Post by: uwe on March 04, 2013, 04:00:19 AM
To be fair, Session Music in Frankfurt is reasonably stocked as regards Gibson basses, they have about half a dozen, a Novoselic RD, a reg Bird, a Nikki Sixx, a Non-Rev, an SG and they will be getting some Midnights, the EB and the ES-335 Basses too. Believe there to be an Oversize LP too. In part, of course, that has to do with me because they know they will always at least sell one specimen, but Marco, who heads the bass department, albeit a card-carrying Fenderista, holds the view "that you're not a real bass shop if you don't always have a Ric and a TBird on the rack as well - they're classics ...". The only thing that bugs me is that all the Gibson basses are out of reach in the rafters while the floor is populated by Fender, Warwick, Ibanez, Sandberg, what have you. Marco says: "The Gibsons just look cool up there and we want them to be seen!", but shouldn't they be played rather than just seen?
Post by: Dave W on March 04, 2013, 09:13:35 AM
They do demos here too. Since this store seems to be the only one in the world with a full stock of Gibson basses, I figured that the Gibson promo would include basses. Maybe not.
Post by: TobaccoRipper on March 04, 2013, 11:40:44 AM
Ok the guys in Frakfurt got some.  The only GC I know is session music in Hamburg and they've got betweenwhiles up to three Gibson basses in the shop. You have to be a extrem lucky guy to be in the right place at the right time to get one. Most of the shops got not even one of these instruments. Sorry I'm very disappointed by the german GC's. I don't ask for the full range of Gibson Basses to be displayed but a few of their classics should be in stock at every big GC.
I would answer Marco that this basses look great indeed but they sound even better.  :mrgreen:
Post by: 4stringer77 on March 04, 2013, 01:20:57 PM
Are people from Hamburg called Hamburgers and are people from Frankfurt called Frankfurters? Sorry, I couldn't help myself.  :D
Post by: TobaccoRipper on March 04, 2013, 01:56:59 PM
You're not going to believe this but you're right!  ;D
We call them "Hamburger", "Frankfurter" an the people from Vienna (Austria) are called "Wiener". Curious, ain't it?
Post by: 4stringer77 on March 04, 2013, 02:17:20 PM
Remarkable. The W in Wiener is pronounced as a V. Wiener schnitzel is one of my faves too. They actually make it a lot in Israel where I've had some very good schnitzel. Usually chicken or veal and not pork though. I also like it mit rotkraut und don't forget the spaetzle. Prost!  :toast:
Post by: Dave W on March 04, 2013, 03:44:14 PM
A schnitzel can be made from any meat, but a Wiener schnitzel is always made from veal.
Unless you're talking about the awful fast food chain Der Wienerschnitzel which was apparently named by someone who thought it was a hot dog (and didn't know that it should have been das and not der)
Post by: 4stringer77 on March 04, 2013, 04:43:49 PM
Poor little baby cows. Anyone who eats veal should watch George Franju's mini documentary of the Paris Slaughterhouses in 1949. It's called Blood of the Beasts. It's a supplement to the Criterion release of the film Eyes Without A Face by the same director. I still enjoy veal on occasion, albeit with a somewhat guilty conscience.
Post by: Pilgrim on March 04, 2013, 04:51:23 PM
Quote from: TobaccoRipper on March 04, 2013, 01:56:59 PM
So is a Frankfurter with a full beer a Frank & Stein?
Post by: uwe on March 05, 2013, 03:33:57 PM
Hamburg is former British Occupation Zone, so that means they had freedom of press early on, but little to eat and lack of goods.
Frankfurt is former American Occupation Zone, so no freedom of press until later, but lots of C.A.R.E. packages and early market freedom.
Which explains why we not only have more Gibson basses today but also why the US stadium rockers like Journey or BÖC would regularly tour Frankfurt, but not Hamburg - no GIs stationed there as guaranteed audience.
Post by: Highlander on March 05, 2013, 03:40:36 PM
Quote from: 4stringer77 on March 04, 2013, 01:20:57 PM
... and people from Phuket are called...?
I still think my favourite named place is the Pidley-cum-Fenton Social Club in Cambridgeshire... or mayber Upper and Lower Dicker in East Sussex...
Post by: Dave W on March 05, 2013, 11:23:23 PM
Let's not forget the two northern Iowa towns of Manly and Fertile, home of Manly men who marry Fertile women. Or vice versa.
Post by: neepheid on March 06, 2013, 03:12:33 AM
A favourite local place name of mine:
(http://s0.geograph.org.uk/geophotos/02/45/89/2458905_f1e8c262.jpg)
original page: http://www.geograph.org.uk/photo/2458905
Post by: uwe on March 06, 2013, 06:21:03 AM
New Age Amazons!!!
Post by: Barklessdog on March 30, 2013, 07:04:24 PM
So Uwe did you order and EB Bass?
The look  is starting to grow on me. i liked the black and tort guard one i saw on TB.
Post by: TBird1958 on March 30, 2013, 09:49:33 PM
It's a little out of the way but I've been here.
Named for a poetess from the isle of Lesbos........
(http://i222.photobucket.com/albums/dd306/veronicasteed/Sappho_zps8ffd9153.jpg)
Post by: Dave W on March 30, 2013, 11:41:35 PM
Quote from: Barklessdog on March 30, 2013, 07:04:24 PM
Yes, the bass in my pic on page 1 of this thread belongs to Uwe, it's just wintering in Minnesota.
Post by: Highlander on March 31, 2013, 03:33:57 AM
John... that new guy in Rome... is he a Catholic or something...?  ;)
Post by: gweimer on March 31, 2013, 05:32:58 AM
(http://farm4.staticflickr.com/3133/2644530015_7c44694668_z.jpg?zz=1)
Post by: exiledarchangel on March 31, 2013, 11:19:24 AM
Quote from: TBird1958 on March 30, 2013, 09:49:33 PM
I have a (female) friend from there. She tried to be straight, she really did, but...
Post by: Highlander on March 31, 2013, 11:31:42 AM
... you drove her round the (banana) bend...? ;D
Post by: amptech on January 22, 2014, 12:06:25 PM
Quote from: Dave W on January 08, 2013, 08:46:25 PM
Ok, old thread.. But a guitar playing friend of mine just came by with a bass he bought ´to have a nice allround bass for home recording´. He looked at Fender P basses and the usual stuff, surprised me when he dug up a 2013 model EB bass.
I havent seen it in shops here yet (they had to order one from sweden last week, only 2 sunburst left in scandinavia??)
and really never thought of looking one up for testing. I only use shortscale basses now, but played a Grabber and a P bass for about 20 years before I fell in love with the shorties...
I´m not a ´reviewer´either, just thought I´d chip in and agree to the positive comments it got here.
I didn´t instantly get the feeling of a bass with a lot of personality, despite the corny looks, but when plugged in I did not want to put it down either. The set neck is nice, feels fine. It also had a decent (not perfect) factory setup.
Sloppy bridge (intonation) but a good low action on a dead straight neck.
I liked the sound of both pickups, single and together. I have to agree also on the neck pup - nice full sound but not muddy. All over, a very clean and focused tone at any setting. Missed a switch, and can´t say the splitting was a huge surprise tone wise, but I think my friend got himself a fine and somewhat versatile tool for recording.
Not tons of tone/personality, but a solid good quality Gibson, I´d say. Not bad for a new bass design!
Post by: Dave W on January 22, 2014, 12:15:06 PM
I've only seen one in a shop here, although they seem to be plentiful enough at the online stores in the US.
Maybe Uwe can give us an update now that he's had this one about nine months.
Post by: uwe on January 22, 2014, 04:03:37 PM
Uwe can't really - he's been out of a job musicwise for quite some time (since late summer now) and is still looking for a band that needs a lead bassist.  :mrgreen: And doesn't just cover. Yet does not only consist of 20 year-olds still trying to "make it big". Plus doesn't sing bad English lyrics. Nor does heavy metal, punk or grunge (that grunge audition was physically painful). Oh, and I don't like guitarists with drop-D tuning either. Riffs sound messy to me that way. If you play a riff, play it on the D and G string for Christ's Blackmore's sake. All good riffs were played on the D and G string: Smoke on the Water, Burn, Man on the Silver Mountain, Long Live Rock'n'Roll, All Night Long, Knocking on your Backdoor. I have an accustomed ear, you know.
But I'm not that difficult at all, really. I'm just looking for an amateur band with professional quality control whose own music sounds like a mix of Tin Machine and Be-Bop Deluxe with a touch of Blue Öyster Cult and early Police. That should be easy to find. Oh, and they must want to play my own stuff besides their own compositions too and be willing to write jointly.
Serious applicants only please send an email.
Coming back to the EB ... I played both the 4- and the 5-string in extensive rehearsals some time back. Was first disappointed, then they grew on me, you can do something with those sounds. Liked the 5-string a bit better for whatever reason, I don't like 5-strings much in general. The narrow magnetic field of the pups is a major letdown for me, I'm Ariel Bender. But if you don't bend, you won't even notice it all the way from Memphis. Or Nashville.
In essence, the EB lacks a bit, no, lacks a lot of an axe-factor and the headturner element for me. I'm vain enough to want to impress people with the look of a bass even if I haven't played a note yet. Explorer basses are great that way. The EB is - no two ways about it - not an Explorer bass. At all. As unsexy as Gibson IV and V. That is pretty unsexy. Not even ugly and proud of it.
But I applaud that they attempted something different and were not content to masticate the same model over and over. And call it Rickenbacker 4003W or something.  ;)
As I'm typing this, I'm listening to The Dictators' magnificent Steppin' Out. That wouldn't be a bad band to join either.
Post by: Dave W on January 22, 2014, 09:38:31 PM
I can totally see you replacing Andy Shernoff.  ;)
The EB Bass is definitely not an Explorer, I'll grant you that. But I've never cared for the Explorer shape.
Post by: Psycho Bass Guy on January 22, 2014, 11:14:35 PM
Quote from: uwe on January 22, 2014, 04:03:37 PMBut I'm not that difficult at all, really. I'm just looking for an amateur band with professional quality control whose own music sounds like a mix of Tin Machine and Be-Bop Deluxe with a touch of Blue Öyster Cult and early Police. That should be easy to find. Oh, and they must want to play my own stuff besides their own compositions too and be willing to write jointly.
I don't see anything wholly unreasonable there. Very few musicians know themselves or music well enough to be articulate enough to have a list like that. The fact that you do should be a plus to any true group of musicians even remotely likeminded. It ain't my cuppa tea, but that's what makes the world an interesting place. BTW, I'd figure that EB would be PERFECT for your list. Even though you'll never admit it, your Explorer days are behind you. ;)
Post by: Ampig on January 23, 2014, 12:59:10 AM
I've bought the 5 string a while ago.  Been rehearsing with it for a few weeks now, and I must say I'm pretty impressed with this bass.  Nice punchy, smooth midrangey sound.  Don't know about the four string, but the neck on the fiver is flat, yet very wide. Eventhough you get kind of a flightdeckship-feel, it really plays very comfortably.
I think that in this pricerange, this might be one of the best fivers out there at the moment.
(http://i.imgur.com/6m8QdQRl.jpg)
Post by: Highlander on January 23, 2014, 01:14:46 AM
... But I'm not that difficult at all, really. I'm just looking for an amateur band with professional quality control whose own music sounds like a mix of Tin Machine and Be-Bop Deluxe with a touch of Blue Öyster Cult and early Police. That should be easy to find. Oh, and they must want to play my own stuff besides their own compositions too and be willing to write jointly...
Mein Gott...! a flock of blau-spotted schwein just flew over heading for London...!
Compromise is key or you'll have to enjoy playing with yourself... ;D
(I'm with you there... the singer I worked with in '09 is still playing small pubs, waiting to be discovered, as Jackie calls it... I was not interested in working with someone who was just the great "I Am...!" :rolleyes:)
Post by: uwe on January 23, 2014, 06:09:41 AM
Basically, I want something urban and slightly quirky, but at the same time it shouldn't be afraid to be dumb and primal sometimes for emotional impact. Does that make sense?
And Dave, I'd naturally talk Andy Shernoff into playing keyboards again (as he did on Manifest Destiny, where Steppin' Out is from, Mark "Animal" Mendoza, who later on joined Twisted Sister - no relation to the other Mark Mendoza who played with Whitesnake and ThinLlizzy -, played bass on that album, Andy tinkled the ivories).
Post by: saltymonkey on January 23, 2014, 10:20:38 AM
The Dictators, sans Shernoff, are actually playing tonight at Bowery Electric in NYC. I'm not in the city this week or would be there. Saw them a bunch. Always a good time.
http://thedictatorsnyc.com
Post by: TBird1958 on January 23, 2014, 10:29:26 AM
Quote from: uwe on January 23, 2014, 06:09:41 AM
Hey! No tinkling on the Ivories!
You may tickle them  ;D
Post by: Dave W on January 23, 2014, 10:35:20 AM
Now that The Captain and Tennille are divorcing, maybe Uwe can team up with Toni. I can see them now: Der Hauptmann and Tennille (with Uwe dressed appropriately).
Meanwhile, The Captain ought to team up with Maggie MacNeal.
Post by: TBird1958 on January 23, 2014, 11:14:46 AM
I think it's Der Gruppenfuhrer Dave  ;D
Post by: Highlander on January 23, 2014, 12:23:10 PM
Hauptmann Hornung, mit ze peaked cap, ze crispen lapel jacket und ze shiny Jackboots, ja...? :o
Post by: uwe on January 23, 2014, 12:57:42 PM
I feel myself pigeon-holed here.  :-\
And then ... the unspeakable, excruciating cruelty of comments such as this one:
"Even though you'll never admit it, your Explorer days are behind you."
I'm a Veteran of a Thousand Psycho Bass Guys, all my scars are on the inside ...
http://www.youtube.com/watch?v=6L1O8SmGeXg
That Metallica clip is living proof for what I have always said: Ever since Hetfield learned to sing (a bit) he is a dead ringer for Eric Bloom.
Post by: Highlander on January 23, 2014, 01:09:55 PM
[Igor] A modicum of solace, Masster... [/Igor]
www.youtube.com/watch?v=eUoonllfMxk
Post by: Dave W on January 23, 2014, 02:51:50 PM
Quote from: TBird1958 on January 23, 2014, 11:14:46 AM
That'll work too. As long as he doesn't have to tinkle the ivories.
Post by: SKATE RAT on January 23, 2014, 03:10:22 PM
i dig the look of the EB bass, but like the newer Rippers, what's up with non painted necks?
Post by: uwe on January 23, 2014, 04:52:32 PM
Quote from: Dave W on January 23, 2014, 02:51:50 PM
You believe there truly is a market out there for an S&M fetish reworking of "Die Liebe hält uns zusammen!!!" (Love will keep us together) with me attired in an SS-Gruppenführer uniform, Rammstein doing the background vocals and Gwyneth Scarlett Johansson being mein Fräulein Tännille? I like how you think. It's an enticing proposition ...
(http://www.hotflick.net/flicks/2008_The_Spirit/big/fhd008SPT_Scarlett_Johansson_009.jpg)
Speaking of the real thing, man was that synth bass busy!!!
http://www.youtube.com/watch?v=xjloX_EvYiI
Post by: TBird1958 on January 23, 2014, 06:09:08 PM
That was gooey back then......................Still is!  :-*
Post by: Psycho Bass Guy on January 24, 2014, 03:18:14 AM
Quote from: uwe on January 23, 2014, 12:57:42 PMThat Metallica clip is living proof for what I have always said: Ever since Hetfield learned to sing (a bit) he is a dead ringer for Eric Bloom.
He learned to sing? I could swear he just learned to whine in (sorta) key.
...and in my defense, you haven't mentioned your spalted Explorer in quite awhile.
Post by: Pilgrim on January 24, 2014, 12:02:34 PM
In vital late-breaking breaking musical industry news, it has just been reported that The Captain and Tennille are divorcing after 38 years of marriage.   :-[
Post by: Dave W on January 24, 2014, 12:20:39 PM
Quote from: Pilgrim on January 24, 2014, 12:02:34 PM
You're late to the party, Al. That's the whole reason I brought up an Uwe/Tennille duo on the previous page.  ;D
Post by: Highlander on January 24, 2014, 01:08:53 PM
Is there any truth in the rumour that Colorado has its own time zone...?
Post by: Pilgrim on January 24, 2014, 11:36:05 PM
Quote from: Dave W on January 24, 2014, 12:20:39 PM
Missed it by THAT much!
(http://i843.photobucket.com/albums/zz353/Batthan/Ethan%20The%20Chain%20of%20the%20Past/MaxwellSmartakaAgent86.jpg)
Post by: TBird1958 on January 25, 2014, 07:56:50 AM
Hmmmm.........................Al, are you taking advantage of certain Colorado legislation  :o
Post by: Pilgrim on January 25, 2014, 10:52:53 AM
Quote from: TBird1958 on January 25, 2014, 07:56:50 AM
Sorry it took me a while to answer....had to finish my nachos.
Post by: chromium on January 25, 2014, 11:33:40 AM
Littering annnd... littering annnddd.....
(nsfw)
http://www.youtube.com/watch?v=0PKtGnyGuKM
Post by: Pilgrim on January 25, 2014, 02:33:53 PM
I'm freakin' out, maaaaaan!
(http://i83.photobucket.com/albums/j306/apowell1/Capture_zps9f07474d.jpg)
Post by: uwe on January 27, 2014, 01:45:45 PM
Quote from: TBird1958 on January 23, 2014, 06:09:08 PM
Pah, I liked it, gooey or not. I have a gooey side you know. And this was in a similar vein and I liked it too!
http://www.youtube.com/watch?v=op0upKxdvLs
I dig keyboard sounds and rhythms like that.
http://www.youtube.com/watch?v=UWdcZqG02Ls
Post by: uwe on January 27, 2014, 01:50:08 PM
Quote from: Psycho Bass Guy on January 24, 2014, 03:18:14 AM
True, but your typical Metallica fan doesn't demand more!
How you rub it in ...  :mrgreen: but just for you I'm taking the spalted one to my next audition, hah!
Post by: Andrew on February 14, 2014, 03:01:49 PM
Tin Machine
There's a band I'm stoked to see mentioned! Good stuff Uwe.  :)
Post by: uwe on February 14, 2014, 03:23:55 PM
I think Bowie did some of his best work with them. Vastly underrated and probably the best rhythm section I have seen - ever. The Sales brothers were telepathic and played the weirdest signature and tempo-leaving breaks I've ever heard. But in perfect sibling harmony! Of course almost all the audience expected a David Bowie concert and were disappointed.
I thought I was the only guy on earth who ever liked Tin Machine!
Post by: Highlander on February 14, 2014, 04:05:45 PM
You're not entirely alone, Sir... ;)
Post by: SKATE RAT on February 14, 2014, 04:11:40 PM
i too liked Tin Machine, though i haven't listened to them in like 20 years
Post by: Highlander on February 14, 2014, 04:29:23 PM
Same here... hmm, maybe time to dip the toe in again...
Post by: Highlander on February 14, 2014, 05:18:10 PM
Dipping...
www.youtube.com/watch?v=QI5hrwnaTkk
Post by: gearHed289 on February 17, 2014, 08:52:19 AM
Big fan here. I remember taping these clips on my VCR 20 years ago...
http://www.youtube.com/watch?v=gydsaQt9j7I
Post by: uwe on February 17, 2014, 09:32:38 AM
Très cool, love those suits, what a fashion statement! It was rock music with an edge, but very urban, I liked that combination, have been looking for it ever since, but whenever people ask me what music I would like to play and I say "Tin Machine type", then I either get blank faces or a surprised "not very many people will want to listen to it then!"  :mrgreen:.
I loved them for the Yardbird'ish riff of that song alone ... plus David still had his original (all over the place) teeth, never liked how those implants changed his smile ... And the music is Progish in parts and really testing the limits, but always coming back to a good tune and riff. Never mind the adorable rhythm section work of Hunt and Tony Sales. Some of the off-the-wall intensity of The Doors come to mind.
http://www.youtube.com/watch?v=m6pV3rfyTFM
Post by: Highlander on February 17, 2014, 04:28:49 PM
I think of it like Neil Young's "ditch" era, or maybe the Geffen one, with him (DB) playing smaller venues and looking like he's enjoying playing live again... doing what he wants to do, and not what the manager expected of him...
