Gear Discussion Forums => Gibson Basses => Topic started by: vates on January 02, 2013, 04:22:38 AM
Title: The placing of Thunderbird II pickup
Post by: vates on January 02, 2013, 04:22:38 AM
First of all: Happy New 2013 Year to all of you, dear forumites!
Well, the idea of T-Bird II build haunts me for the last few years already.
One of the unsolved questions is the issue of pickup placing on original '63-'65 Thunderbird II basses. Some pictures show it exactly close to the central pickguard screw (i.e. the pickup chrome frame upper right angle is placed right next to that screw), other show it an inch or more closer to the bridge.
So where is the truth?
One more thing: how does the pickup placing on original TBrids II relate to the neck pickup placement of modern TBirds IV?
Many thanks in advance!
Title: Re: The placing of Thunderbird II pickup
Post by: uwe on January 02, 2013, 05:43:33 AM
3 1/4" from the fretboard to the side of the neck pup on the sixties ones, 3" on the Bicentennials, 2 1/2" on the post 87 ones. It crept forward over time. I just measured it on all three (and on various specimens to be on the safe side), funny it has never occurred to me before, I though they were by and large in the same position. So your question was a good one.   :)
It (partly) explains why modern Birds have a bit more more oooomph and older ones a bit more roarrr.
Post by: dadagoboi on January 02, 2013, 05:55:06 AM
On both of my 64s (a II and a IV): from the center of the 12th fret to the centerline of the pickup, 10 7/8" (277mm).
...As far as a 'modern' Thunderbird placement, I'm both ignorant and apathetic, don't know and don't care.  "Sweet spot" is determined by the characteristics/design of a pickup.  About the only similarities with original and modern pickups is 2 magnets and 2 coils, differences are alnico vs ceramic, short vs tall, thin wire vs fat, number of winds and metal vs plastic cases.  All of those things make the pickups very different sounding.  Not saying one design is "better" than the other, just different.  You can guess which one is cheaper to make.
On my '77 it's around 10 5/8" 12th fret to centerline.  Those are REALLY different design pickups.  I wouldn't worry about where the pickguard holes seem to be.  Critical distance is the one relating to the neck.
Post by: godofthunder on January 02, 2013, 06:16:02 AM
 One reason I am not a big fan of the modern Thunderbird is the neck pickup placement. 3 1/4" from the base of the neck to the front edge of the pickup is the optimum location at least for me.
Post by: vates on January 02, 2013, 06:34:06 AM
Thank you very much for quick and very informative responses.
However, I still need some clarifications, if you don't mind:
Quote from: uwe on January 02, 2013, 05:43:33 AM
Thank you! Since we're on the same side of the pond, could you please give me the exact measure in millimeters as well? Also, do I understand it correct that you measured from the actual end of the fretboard (wood tip), not the metal wire of the 20th fret? I guess the length of a wooden tip beyond the 20th fret may vary on different birds...
Quote from: dadagoboi on January 02, 2013, 05:55:06 AM
Thank you very much! Do you mean the physical center of the 12th fret (where dot markers are placed) or do you mean the wire of the 12th fret , i.e the actual 1/2 of the scale?
Post by: dadagoboi on January 02, 2013, 09:51:07 AM
Quote from: vates on January 02, 2013, 06:34:06 AM
The centerline of the 12th fret wire.
Post by: vates on January 03, 2013, 03:23:39 AM
Thank you, you are most helpful!
So, considering sixties T-birds were 34 3/8" (34.375") scale, 10 7/8" (10.875") shall be 31.636% of the scale length. Which means that with modern 34" scale that measure from the 1/2 point of the scale to the pickup's center line shall turn into 10.756".
Post by: dadagoboi on January 03, 2013, 08:20:57 AM
Quote from: vates on January 03, 2013, 03:23:39 AM
definitely close enough for Rock and Roll!
Post by: Dave W on January 03, 2013, 09:32:23 AM
I wonder, are the 60s T-birds really 34 3/8" scale length? I ask because Gibson (unlike everyone else) used an estimated compensated scale length in its guitar specs rather than the exact uncompensated scale length of 2x the nut-to-12th-fret distance. For example, guitars listed as 24 3/4" scale are actually 24 7/16" to 24 9/16" depending on the year, and the several EB-0Ls I've measured were 34" despite being listed as 34 1/2". The regular EB-0s I've measured were all 30 1/8" despite being listed as 30 1/2".
Quote from: dadagoboi on January 03, 2013, 08:20:57 AM
Agreed. I'm just asking whether the old ones really are longer.
Post by: dadagoboi on January 03, 2013, 10:10:33 AM
Quote from: Dave W on January 03, 2013, 09:32:23 AM
On my '64 TBirds distance from front of the nut to 12th fret centerline is 16 15/16 inches.  The same as Fender, Hamer, Warmoth, Vox and Epiphone (both Embassy and Explorer) 34 inch necks I just checked.  So it's 34 inch scale.
Gibson mislocated the bridge.  To properly intonate a '60s bird the bridge has to be moved closer to the neck, which is what a Badbird does.
Post by: godofthunder on January 03, 2013, 11:16:31 AM
Post by: vates on January 03, 2013, 02:18:40 PM
Brilliant! So I need an absolute value after all...
Dear uwe, could you please answer this question?
...so the more actual measure will be from the metal wire of the 20th fret. could you please check this out? Vielen Dank im Voraus!
Post by: uwe on January 03, 2013, 06:07:53 PM
My dear metrical friend, stuck like I am among imperial measurement savages, I will dutifully centimeterize tomorrow when I'm back in the office.
Post by: Dave W on January 03, 2013, 06:28:23 PM
Quote from: dadagoboi on January 03, 2013, 10:10:33 AM
Thanks, Carlo, that confirms my suspicions.
Post by: vates on January 03, 2013, 11:10:50 PM
Quote from: uwe on January 03, 2013, 06:07:53 PM
uwe, you remind me Skipper a bit when you say so :)
(http://nick.mtvnimages.com/nick-assets/shows/images/penguins-of-madagascar/characters/character_thumb_310x175_skipper.jpg)
actually the accents in my numerous questions shifted to the issue of measure from the presumably constant 20th fret, not the presumably various wooden tips of necks' bases. thank you
Post by: Bionic-Joe on January 03, 2013, 11:25:32 PM
Yes...My 3 1960's reverse thunderbird II's are 34" scale as well......Bridge should be moved closer to the neck by about 1/4".....or buy Scott's Badbird Bridges....
Post by: mc2NY on January 05, 2013, 09:49:25 AM
Don't worry Uwe.....Baz and I and the millions of other Americans measure bullets in metric !!!
Plus we also fix out crappy import cars with metric wrenches after they fall apart   ;D
Post by: Highlander on January 05, 2013, 02:11:35 PM
Boeings used to have these nasty things called TRI-WING fixings back in the day... don't know if they still do...
I still can't think of my height in metric and the thought of not being able to drink a pint of London Pride... or maybe a Spitfire... :toast:
Post by: 4stringer77 on January 05, 2013, 02:21:07 PM
English pints are nice. When I really want to tye one on I go for a Litre. Hofbrau Dunkel is one of my faves.
Post by: TBird1958 on January 05, 2013, 03:29:22 PM
I need a metric system weekend........  :rolleyes:
Post by: Pilgrim on January 05, 2013, 06:12:33 PM
My garage is bi-standard.  I have both SAE and metric tools.
I guess my garage should come out as "bi".
Post by: uwe on January 06, 2013, 03:58:38 AM
Quote from: mc2NY on January 05, 2013, 09:49:25 AM
That's really gunning for a point blank argument.
Post by: TBird1958 on January 06, 2013, 10:01:05 AM
They're always better chromed  ;D
(http://i222.photobucket.com/albums/dd306/veronicasteed/RD015-1.jpg)
Post by: Highlander on January 06, 2013, 10:29:32 AM
A little bit too far out of the closet, me thinks... ;D
http://www.youtube.com/watch?v=AwzaifhSw2c
Quote from: uwe on January 06, 2013, 03:58:38 AM
Don't bite (the bullet) ... ;)
Post by: uwe on January 06, 2013, 11:33:03 AM
What closet, I cry!!! She's been out of the model train tunnel for long!
Post by: vates on January 06, 2013, 12:49:55 PM
Ah, I can see off-topic is really among common decencies  here :)
I'll try to bump the thread back to its original rails though:
Quote from: vates on January 03, 2013, 11:10:50 PM
Post by: TBird1958 on January 06, 2013, 01:50:18 PM
Quote from: uwe on January 06, 2013, 11:33:03 AM
Just a different kind of fun  :o
Most of that stuff is actually stage clothes.
Post by: Highlander on January 06, 2013, 04:07:20 PM
Yeah, but what kinda stage...?
Post by: mc2NY on January 06, 2013, 08:45:37 PM
A few days before this metric discussion, I actually went out to three stores in NY trying to BUY a metric ruler or tape measurer and could not find one. I ended up coming home and having to convert U.S. inches to metric online, just to convert non-U.S. metric bass hardware measurement. I was trying to compare some to specs given on U.S. basses to metric replacement parts.
I do admit that metric measurements make a lot more sense...especially when our currency is already based on tens. I used to think we just didn't use it in the U.S. so foreigners would get frustrated and stay home...except our pals in Liberia and Burma (the only two other countries that still use our system) :)
But think of all the American classics that would be lost that have movie titles or song lyrics about "miles" or  "inches" or "pounds." Maybe we just  cannot change for art's sake?
Post by: Bionic-Joe on January 06, 2013, 10:23:20 PM
Mark...is that Bullet Belt legal??? It soon may become Illegal under our current administration.........
Post by: TBird1958 on January 07, 2013, 08:23:07 AM
Quote from: Baz Cooper on January 06, 2013, 10:23:20 PM
It's legal Baz, yummy chromey .303's. Were I travelling outside the country with the band I'd be concerned about Customs, otherwise I'm fine  ;)
Post by: uwe on January 07, 2013, 02:04:50 PM
Quote from: vates on January 03, 2013, 02:18:40 PM
VoilĂ , from the 20th fret to the front edge of the neck pup in metric:
Sixties bird: 9,5 cm
Bicentennial: 9,0 cm
Post-87 Bird: 7,8 cm
Post by: vates on January 07, 2013, 03:23:24 PM
Vielen Dank!
Post by: Highlander on January 08, 2013, 03:39:13 PM
European weights and measures has had a glitch...
Somehow, they have discovered that the platinum"standard" for the kilogram is slightly the wrong weight... slightly lighter than they measured it last...???
Post by: vates on July 09, 2013, 06:43:40 AM
Well, I browsed through this forum (a lot) and found this measures' picture of an original NR TBIV (see attached).
Could someone please verify if the neck pickup position of an NR is identical to reverse IV? (and presumably the neck pickup of the latter is in the same position of the TB-II...)
Or maybe there is a similar picture of a reverse '64 TBird and I've missed it: so please point me in the right direction.
I just want to make everything right  ;D
Post by: Highlander on July 09, 2013, 04:35:11 PM
That's George's pic - he'll answer that one I guess...?
Post by: OldManC on July 11, 2013, 12:32:16 AM
If I ever measured my reverse birds I can't remember where the results are. Sorry! All I have of proper Gibson birds these days are a couple Bicentennials. Maybe Uwe can step in if he sees this.
Post by: uwe on July 15, 2013, 05:51:36 AM
What am I supposed to measure again? I will dutifully do so if exact orders are given.
Post by: vates on July 15, 2013, 06:03:39 AM
Uwe, could you please check if the placing on your reverse-Tbird II is similar to the scheme above? You've already replied in this topic, so just to make everything clear. Thank you
Post by: dadagoboi on July 15, 2013, 09:30:19 AM
Quote from: OldManC on July 11, 2013, 12:32:16 AM
They are the same.
Post by: uwe on July 15, 2013, 01:17:20 PM
Quote from: vates on July 15, 2013, 06:03:39 AM
It is. Exakt dasselbe.
Post by: vates on July 15, 2013, 04:12:17 PM
Now that is strange. According to your previous calculations:
276.22500 mm
Quote from: dadagoboi on January 02, 2013, 09:51:07 AM
And the scheme above shows that there are 10 11/16 inches (271.4625 mm) from the 12th fret to the centerline of the neck pickup.
That is a difference of 4.7625 mm. And it is the latter that made me to renew this thread (after I found that picture and compared it to results of my previous insvestigation)
Post by: the mojo hobo on July 15, 2013, 07:01:25 PM
If you want to pick nits look at it again. If the front edge of the pickup is at 10" and the back edge is at 11 1/2" the centerline must be 10 3/4 or it is not the center line, it is the off-center line ;D
Post by: ilan on July 15, 2013, 11:21:36 PM
This reminds me of a very similar discussion on the Wishbass forum.
Post by: 4005 on July 16, 2013, 01:04:48 AM
I could go & check my old Birds but I'm having too much fun reading all this, also I'm kind of afraid what I may find, once I wanted to see if the truss rod cover could be interchangeable, and both the '64s & the 77 screw holes were all different, and the '68? Forgetaboutit!
Post by: dadagoboi on July 16, 2013, 02:28:13 AM
Quote from: vates on July 15, 2013, 04:12:17 PM
276.22500 mm
Gibson mislocated the bridge by 1/4" on both the Reverses and NRs.  Are you going to do that with your build to be historically accurate?
Seriously, because of the mislocation of the bridge on both Reverses and NRs I believe the dimensions were supposed to be the same.  The discrepancy is probably due to the set neck, either where the pocket was cut or the length of the neck heel or both.  I think we've seen some sloppiness there.  With a neck through there's less of a chance for variation in dimensions, though fretboard placement could be a factor.
Let's measure ALL the NRs and do a pie chart.  Lemon meringue.
Post by: vates on July 16, 2013, 03:41:30 AM
This particular measure is from a presumably stable 12th-fret. It is a constant that does not relate to bridge re-positioning and fretboard ends' cuts. Perhaps, Gibson moved the neck pickup closer to the well neck on NRs. That is possible, because on later reverse birds it crawled even further north. However, this comment somewhat ruins such hypothesis:
Quote from: uwe on July 15, 2013, 01:17:20 PM
Post by: dadagoboi on July 16, 2013, 04:27:01 AM
Quote from: vates on July 16, 2013, 03:41:30 AM
"Presumably stable 12th fret."  Why do you presume that when you're splitting millimeters?
I'm quite aware that bridge positioning has no affect on fret to pup route distance. I used that as an example of Gibson's ineptitude at not correcting the bridge misposition when switching over from Revs to NRs. I didn't say end cuts, I was referring to placement of the fretboard on the neck which would affect 12th fret distance to a pup route.
Perhaps Gibson moved the pickup purposely but I seriously doubt it.  Do you have actual knowledge of woodworking techniques and tolerances or are you strictly a theorist?
Post by: vates on July 16, 2013, 04:46:21 AM
AFAIK, Gibson misaligned the bridge on T-Birds due to the bad engineering of the bridge design: they did not take into account the mutes (maybe that bridge was designed without mutes and then thy added mutes due to marketing reasons: I've encountered different interpretations). So they had to move the bridge a little bit further on the final blueprints.
On the other hand, the calculation of the fretboard's part of the scale were consistent: so the position of the 12th fret should be stable on all T-Birds, rev. or non-rev.
And the only thing that matters in terms of sound is the position of a pickup in relation to the scale. So we should look at the scale's constant, 12th fret. What's wrong with that?
Post by: vates on July 16, 2013, 05:05:19 AM
Quote from: the mojo hobo on July 15, 2013, 07:01:25 PM
You're right. All those measures don't correspond to each other. For example, pickups' widths are different, and their centerlines are all over the place. Gonna forget about this picture and stick to the initial data :)
Post by: Dave W on July 16, 2013, 08:50:30 AM
Quote from: ilan on July 15, 2013, 11:21:36 PM
No doubt a few millimeters can make a huge difference in the nuanced tone of a Wishbass.  :mrgreen:
Do they also discuss the effect of a tone knob that's not connected to the circuit?
Post by: uwe on July 16, 2013, 09:12:37 AM
This discussion is beyond the capacities of my mind but I would like to state for the record:
- I only measured to the front edge of the neck pup.
- On my Non Reverse Birds (both my 66 and my 67) that front edge is 5 mm closer to the 20th fret than on my 64 and 65 Rev Birds - it is a factor for the bassier sound that Non Revs have and are often liked for.
Post by: dadagoboi on July 16, 2013, 09:32:36 AM
Quote from: vates on July 16, 2013, 04:46:21 AM
IMO mutes have little to do with the bridge in the wrong place.  Incompetence or indifference are the culprits.  Someone should have checked the prototype and made adjustment.
Pickup choice is going to have a lot more to do with sound than a few mm either way in location.  Will you be using Reverse or NR pickups?...they're different, in part to Gibson's inconsistency, no revolution counter on their pickup winder.  They were wound to a timer monitored by the operator and the number of winds varied according to how attentive they were.  This is well documented.  When Gibson quit winding pickups Seymour Duncan bought the winding machines and installed counters.
Then we can talk about wood choice- are you using genuine Honduras?   Big difference between that and what passes for mahogany these days and it does affect sound.  Then the finish argument, fret width, strings etc. ad nauseum.
Quote from: uwe on July 16, 2013, 09:12:37 AM
-The bassier sound has a lot more to do with the overwound NR pickups which reduce high end output.  Very similar to any overwound humbucker.
Post by: vates on July 16, 2013, 10:08:45 AM
Thank you all for your suggestions! Other issues like woods, pickup type, finish etc. will be disclosed in a dedicated build thread.
Here I wanted to get the exact figure for the neck pickup position of '64 TBird II.
The most valuable info was provided already on the first page:
Quote from: godofthunder on January 02, 2013, 06:16:02 AM
Quote from: uwe on January 07, 2013, 02:04:50 PM
The picture of the non-rev bird with different figures just confused everything.
Post by: uwe on July 17, 2013, 07:56:47 AM
Quote from: dadagoboi on July 16, 2013, 09:32:36 AM
"On my Non Reverse Birds (both my 66 and my 67) that front edge is 5 mm closer to the 20th fret than on my 64 and 65 Rev Birds - it is a factor for the bassier sound that Non Revs have and are often liked for.
You learn something new everyday. You mean sixties Non-Revs have different pups to sixties Revs?  :o Because my sixties Non-Revs sound bassier than my two sixties Revs. No comparison to a modern - and here so often unjustly derided - TB Plus though (whether on a Rev or a Non Rev). The love for vintage pups is inherently nostalgic IMHO, there I said it.
Post by: dadagoboi on July 17, 2013, 08:13:53 AM
Quote from: uwe on July 17, 2013, 07:56:47 AM
Yeah, that's why I got Steve to make ThunderBuckers in various specifications: '63 (Reverse) and '66 (NR).  The number of copper winds is greater on the NRs.  More winds equal darker and louder.  That may have been a conscious decision by Gibson, all the NR (chrome) pickups I've seen are hotter than the Rev ones.  Basically the bridge Rev is a neck NR and the NR bridge proportionally hotter.
Then we went on to the MAX (Scott's favorite) which is overwound as much as possible using original thin wire (over 2 miles per pickup) and hotter Alnico magnets.  Because of that a MAX is 3db hotter than a '66, twice the output.  It's old technology taken as far as it can be.
Post by: Rob on July 17, 2013, 01:36:18 PM
Dayum!  That is a LOT HOEER.  I have watched the discussions but didn't realize just how much overdrive there could be. :thumbsup:
Post by: dadagoboi on July 17, 2013, 02:31:03 PM
Anything worth doing is worth overdoing!
Post by: Highlander on July 17, 2013, 03:41:18 PM
Guilty as charged... ;D
So where does the Mudbucker figure in the overwound status of pups in general...? They are 2x15k iirc ...?
Post by: Dave W on July 17, 2013, 06:38:51 PM
Quote from: CAR-54 on July 17, 2013, 03:41:18 PM
Mudbucker is hugely overwound and is a different design, doesn't sound like any T-bird pickup.
Post by: Highlander on July 17, 2013, 11:55:16 PM
That I know... I recorded some of the sounds of the split coil as a reference for when I (eventually :rolleyes:) get around to fitting the Lollar pup in the PC...
Post by: dadagoboi on July 18, 2013, 05:22:07 AM
Novak Fatbucker, customer supplied for an NR I'm building.  Two single coils in series.  Note how big the wire visible in the bottom of the right coil is.  It will sound very different from a Mudbucker...I don't know exactly how I'm going to adjust the thing yet, the screws are ornamental.
(http://i976.photobucket.com/albums/ae241/cata1d0/ME/P1040536_zps1be72c14.jpg) (http://s976.photobucket.com/user/cata1d0/media/ME/P1040536_zps1be72c14.jpg.html)
(http://i976.photobucket.com/albums/ae241/cata1d0/NR%202012/P1040493_zps1733645b.jpg) (http://s976.photobucket.com/user/cata1d0/media/NR%202012/P1040493_zps1733645b.jpg.html)
Post by: Dave W on July 18, 2013, 08:06:02 AM
^^^ It would have to be clearer, wouldn't it? Bigger wire = fewer winds = less mud.
Post by: dadagoboi on July 18, 2013, 09:15:23 AM
Quote from: Dave W on July 18, 2013, 08:06:02 AM
Yep, should be.  Also a lot cheaper in terms of copper.  It's a very nice looking pickup, looking forward to seeing how it sounds
Post by: exiledarchangel on July 18, 2013, 10:41:48 AM
Quote from: dadagoboi on July 18, 2013, 05:22:07 AM
You mean the central 4 screws? I think they don't play much role in this design anyway. That's a very nice pickup, please keep us (clip)posted! :D.
Post by: dadagoboi on July 18, 2013, 11:02:49 AM
Quote from: exiledarchangel on July 18, 2013, 10:41:48 AM
On the originals they do have an effect on string response depending on height.  Will keep you posted but the build is fourth in line after basses going to Japan and Italy.  Probably late October before it's installed.
Post by: exiledarchangel on July 18, 2013, 11:52:33 AM
Yes, but the effect is minimal, that's what I mean. October doesn't seem very far away... ;)
Post by: dadagoboi on July 18, 2013, 12:00:23 PM
Quote from: exiledarchangel on July 18, 2013, 11:52:33 AM
You're right, they don't do a lot!
Post by: Psycho Bass Guy on July 19, 2013, 12:57:13 AM
...to a point: heavier gauge wire is going to have a larger inductive potential which means more current output as opposed to higher voltage output of overwound thinner gauge wire, and more current equals more low end. My guess is that the Novak should have a similar low end to a Sidewinder without being as nasal and limited in the highs.
Post by: Highlander on July 19, 2013, 03:13:26 AM
Has anyone "mapped" the magnetic field of pups...?
Post by: dadagoboi on July 19, 2013, 03:39:19 AM
Quote from: Psycho Bass Guy on July 19, 2013, 12:57:13 AM
Upon closer inspection this IS a sidewinder, Novak's mod being smaller coils (.5 x .675 ") and big wire.  Reads 13.7k.  He has (had?) another version that uses tele size bobbins straight up with rod magnets.
Another factor (according to Steve):what makes a mudbucker so muddy-over the top- is the millions of turns of tiny wire raises the resistance so high that the interwinding capacitance kills the highs.  So if you want a lot of output but keep the highs you need to get the R down, and fatter wire will do that.  If you still need a lot of turns, bigger wire needs more room, but a mudbucker can has LOTS of room.
Quote from: CAR-54 on July 19, 2013, 03:13:26 AM
Mapping magnets is something SS does for "fun".  This involves improving electric motor efficiency by mapping the magnets leading to the optimum field.
https://docs.google.com/viewer?a=v&pid=gmail&attid=0.1&thid=13f9cd527aa66972&mt=application/pdf&url=https://mail.google.com/mail/?ui%3D2%26ik%3Dd84ad732a7%26view%3Datt%26th%3D13f9cd527aa66972%26attid%3D0.1%26disp%3Dsafe%26realattid%3Df_himd9usb0%26zw&sig=AHIEtbTF71-koUXseQFW2TvHVE-kOXYGkw
I guess he could do pups but there's really no benefit I can see.  Sounds good, is good!
Post by: Highlander on July 19, 2013, 03:57:55 AM
Go to bed Carlo... it's past your bed time...!  ;)
(I need to sign up for that one but the tiling beckons or SWMBO will be on my tail)
Post by: clankenstein on July 19, 2013, 05:02:56 PM
mmm interesting pickup .a full fat sidewinder with added clarity could be mighty tempting.how many k ohms is it?
Post by: dadagoboi on July 19, 2013, 05:39:34 PM
Quote from: clankenstein on July 19, 2013, 05:02:56 PM
It's neither full nor fat:
Quote from: dadagoboi on July 19, 2013, 03:39:19 AM
...smaller coils (.5 x .675 ") and big wire.  Reads 13.7k.
