I was wondering if there's a large enough cover that you could fit in a normal Precision splitcoil? I have a Precision body which has plenty of room for some experiment and I reversed the P-pickup 'cause it sounds better that way with the added Jazz Bass bridge PU. However I'd like to cover the P-pickup 'cause it looks a bit starnge reversed and also because the large cover Neil Murray had in his old Telecaster/P-bass hybrid looked so cool.:)
(http://www.musicpictures.com/pictures/600/4MPRW02_7815313_Neil_MURRAY_6.JPG)
If I understand correctly, a P pickup cover will fit over a P pickup whether the pickup is reversed or not. Should not be a problem at all.
I think he means a square cover like a humbucker
I have two spare Epiphone mudbucker covers. I tried it, but they're to small to cover a split P. You could make something yourself? A chrome cover, or like Billy Sheehan a piece of pick guard?
(http://www.portlandpercussion.com/yamaha/yamattitude.jpg)
Quote from: Iome on September 28, 2011, 10:00:50 AM
Yes indeed, like in that pic above.
Quote from: Chris P. on September 28, 2011, 10:31:47 AM
I thought that too, just wanted to ask if there's anything large enough available. Better start digging up old soapboxes.:)
Is that a model one in that Precision...? saw them often enough but just don't remember that one, might have to dig through my pics to see as I have a quite a few hundred pics of that era WS...
So....why not use a Fender cover on a Fender-style bass? ???
Quote from: BUFF on September 28, 2011, 03:08:54 PM
No, I once asked Neil what that pickup was and he said it was a Mighty Mite split coil reversed IIRC. I should ask him again.
Quote from: Pilgrim on September 28, 2011, 06:05:21 PM
As I said, I don't like the looks of a reversed P pickup and I like the looks of that large cover Neil had in his bass. Of course I could put a Model 1 in that hole (there's room) but as I have a good matching pair of P & J from 80's Jazz Bass Special it's cheaper to find or make a cover for it. The pickguard has to be re-cut too so the cover fills the nasty hole in that too.
Or do you mean an ashtray with the 'Fender cover'?
Quote from: Pekka on September 28, 2011, 10:53:03 PM
Hmmmm...not sure. I may have missed something.
My vote is generally for both covers, just coz I like the bling and they don't get in my way. But I know that's not the case for everyone. Shouldn't be too hard to get measurements on whichever cover you like.
Quote from: Pilgrim on September 29, 2011, 09:15:53 AM
Yes, just wanted to ask if there's large enough covers on the market already. I guess the D.I.Y. option is the way to go.
Are those the Jazz Special pickups with the larger pole pieces? I was looking for some of those.
Quote from: Nokturnal on September 29, 2011, 12:16:31 PM
Yes. A bit like QP's but not as large (at least I think, I haven't compared).
Hmmmmmm......You know, I have a Model 1.........if you decide not to use those pickups let me know.
Quote from: Pekka on September 28, 2011, 10:48:09 PM
Well, I did and he had 4 Mighty Mite P -pickup halves trimmed and fitted in under a cover he made from regular P-bass PU covers. He therefore could use whatever combination he wanted and ended up using mostly the one with D&G closer to the neck and E&A closer to the bridge = the reverse P.
The bridge pickup was two Jazz PU's wired together.
After a year or so I finally got it made. The cover is made from 4 P-bass covers and the pickup is in a reversed position (ala Yamaha BB2000, Spector NS-2 etc.). Allparts Teleneck and some old Schaller tuners. The bridge PU will be replaced by a humbucker and I'll add a switch for mono/stereo.
(https://dl.dropbox.com/u/4322198/IMG_2112.JPG)
A string guide will be added, it just don't look right without it.:)
a fender humbucker cover?
Quote from: nofi on December 01, 2012, 02:58:43 PM
I doubt it but anyway it doesn't matter anymore. The bass sounds great and I really love the Tele neck. If I ever get myself a Fenderbird the neck has to be the D neck.:)
Here's a short sharp clip of all the pickup combinations:
https://dl.dropbox.com/u/4322198/Untitled1.mp3 (https://dl.dropbox.com/u/4322198/Untitled1.mp3)
(https://dl.dropbox.com/u/4322198/nmpb1.jpg)
(https://dl.dropbox.com/u/4322198/nmpb2.jpg)
Nice... ;)
I modified it a bit more. Now it has two Dimarzio DP122's in reversed positions and in custom covers. Very punchy!
(https://dl.dropboxusercontent.com/u/4322198/IMG_4534.JPG)
